-   -   detroit speed & engineering (https://www.lateral-g.net/forums/showthread.php?t=36812)
Flash68 05-12-2012 06:19 PM
Originally Posted by chr2002ca (Post 413804)
You could try wrapping the carrier in several layers of Dynamat. It worked great on the whining noise my first wife made.
:rofl: That's a winner.
coolwelder62 05-12-2012 07:02 PM
If the gear set is whinning when power is on,& no noise when off the throttle this is an indication it's time for a new ring & pinion.
FETorino 05-12-2012 07:04 PM
Its time to change the oil anyway swap to Lucas 85 / 140.
If that and some more break in miles isn't quiet enough plan B.
hulsund 05-12-2012 07:10 PM
Is whinning when i cruising on the higway ,will try to change oil and use 80-140
Vegas69 05-12-2012 08:43 PM
Since when should properly set up gears whine? I've never heard a peep out of mine. Of course, my cars not a kitten either. :D
Matt@BOS 05-12-2012 09:58 PM
Yeah, but even if it did, we certainly wouldn't been able to hear it over the whining about brake pad knock back, or valve lash, or whatever else has to get changed out on big blocks frequently :lol:
Matt
Flash68 05-12-2012 10:04 PM
Originally Posted by ratman67 (Post 413915)
you must be running a pansy exhaust system if you can hear anything other than the engine...put some free flowing mufflers on the car, then buy a mans sound system and let her rip, problem solved....
:lol: :thumbsup:
Did I read/hear that 9 inchers are more prone to this noise than 12 bolts? Thought I did.... :question:
Vegas69 05-12-2012 10:08 PM
Matt
Don't change the subject. :lol:
Originally Posted by Flash68 (Post 413928)
:lol: :thumbsup:
I was wondering the same thing.
