-   LSX Conversions (https://www.lateral-g.net/forums/forumdisplay.php?f=70)
-   -   Ls6 to 69 camaro conversion kit (https://www.lateral-g.net/forums/showthread.php?t=46814)
jeeper90 07-27-2014 04:13 PM
Originally Posted by Snipe00 (Post 560295)
Check out this book. I plan on doing the swap in future so i bought this to read through.
Is this book worth buying?
rickpaw 07-30-2014 08:00 AM
Originally Posted by 69lsvert (Post 560024)
Going back with stock console that has gauges in it and stock dash that a tic tock tach.
You also need to address the gauges hook up as well, especially the speedo/tach The stock mechanical speedo won't work with the electrical output from the ECU/trans, so you'll need some kind of converter.
I took the easy route and went with Dakota Digital's VHX gauge set up.
OBeer-WAN-Kenobi 07-30-2014 08:11 AM
Me too. Just connected the wires and ran the setup on the fuel gauge, tach and speedometer. After that, working gauges. (I had a bad brain box the first go around but Dakota took care of it and second one worked flawlessly).
You'll need an OBDII port to wire in as well.
69lsvert 07-30-2014 09:02 AM
Does the Dakota gauges have the console gauge setup like the tach and speedo?
69lsvert 07-30-2014 09:05 AM
Also what transmission mount did you go with for the t56? Prothane looks good. I have the Holley crossmember.
OBeer-WAN-Kenobi 07-30-2014 10:07 AM
I got these:
http://www.dakotadigital.com/index.c...rod/prd722.htm
You also have a choice to get the ones set up for console gauges:
http://www.dakotadigital.com/index.c...rod/prd849.htm
Or you can get the all digital stuff. Personally I don't like the looks:
http://www.dakotadigital.com/index.c...rod/prd166.htm
rickpaw 07-30-2014 11:18 AM
Originally Posted by OBeer-WAN-Kenobi (Post 563447)
I got these:
x1. Unless you're dead set on original look.
MaxHarvard 07-30-2014 01:00 PM
I say it is, but i'm a bit bias ;)
Carbo 07-30-2014 09:30 PM
Just got my LS and will be starting my swap in the next six months. Still doing homework so I'm paying attention to this thread. Keep the info coming.
69lsvert 07-31-2014 12:53 AM
Guys that are thinking about ordering Holley ls/t56 swap, the one I ordered didn't come with trans mount and you have to use a clamshell mount off a 73 camaro. I ordered mine from Summit or probably go to your local auto parts store and get them.
Motor and Trans are going in Saturday so I'll try and post some pics.
