-   -   Project SCHEVY 2001 Silverado full frame build (https://www.lateral-g.net/forums/showthread.php?t=16721)
camaro2nv 12-30-2008 09:12 PM
Just awesome skills! Great job! As someone trying to learn fab work man this thread impresses me!
GMracer 12-30-2008 09:22 PM
thanks man, that really means a lot. :)
GMracer 01-05-2009 07:52 PM
Quick update
Started my lower link brackets, 3 position adjustable
http://i83.photobucket.com/albums/j3...o/HPIM1769.jpg
http://i83.photobucket.com/albums/j3...o/HPIM1763.jpg
http://i83.photobucket.com/albums/j3...o/HPIM1760.jpg
http://i83.photobucket.com/albums/j3...o/HPIM1762.jpg
http://i83.photobucket.com/albums/j3...o/HPIM1759.jpg
http://i83.photobucket.com/albums/j3...o/HPIM1765.jpg
Both bars at 0*
http://i83.photobucket.com/albums/j3...o/HPIM1767.jpg
And roughly where the bags will sit
http://i83.photobucket.com/albums/j3...o/HPIM1771.jpg
These are NOT the bags I'm using, I'm going to run the new f9200s instead, and the upper link bracket will probably be part of the bag bracket.
GMracer 01-14-2009 01:44 PM
Wanted to add a gusset for the upper link mounts
http://i83.photobucket.com/albums/j3...sto/Jan730.jpg
http://i83.photobucket.com/albums/j3...sto/Jan731.jpg
http://i83.photobucket.com/albums/j3...sto/Jan728.jpg
Finished up the lower link mounts
Had to bend and weld them together
http://i83.photobucket.com/albums/j3...esto/Jan72.jpg
Welded them up and added a gusset
http://i83.photobucket.com/albums/j3...sto/Jan723.jpg
GMracer 01-14-2009 01:45 PM
http://i83.photobucket.com/albums/j3...sto/Jan726.jpg
http://i83.photobucket.com/albums/j3...sto/Jan712.jpg
http://i83.photobucket.com/albums/j3...sto/Jan713.jpg
Finally designed and made my under engine bolt in crossmember
http://i83.photobucket.com/albums/j3...sto/Jan719.jpg
http://i83.photobucket.com/albums/j3...sto/Jan718.jpg
http://i83.photobucket.com/albums/j3...sto/Jan720.jpg
http://i83.photobucket.com/albums/j3...sto/Jan721.jpg
COYBILT 01-14-2009 09:47 PM
once again this is impressive, Its not everyday you see a truck like this.
There was a guy about 4 years ago that did the same thing with a 2003 or 2004 extended cab short bed. He built a tube chassis for it and it layed rocker with out much of body drop. I was impressed and he was I think 23 or 24 years old. It was the stock dark metallic blue that came on 05 silverado's.
GMracer 01-15-2009 04:29 AM
thanks man, I'm interested in seeing that truck, haven't seen it. I was going to lay rocker, but I decided to keep it .75" away just to keep my rockers safe.
deuce_454 01-15-2009 04:32 AM
you big chicken! LOL:D
GMracer 02-09-2009 12:52 PM
CAB IS ON!!!!
So I finally got my new rear bags, f9100s and at $200 a pc I was skeptical, till they showed up and I love them. On the right is a f9000, (blue tape protecting the billet)
http://i83.photobucket.com/albums/j3...o/HPIM1846.jpg
http://i83.photobucket.com/albums/j3...o/HPIM1847.jpg
http://i83.photobucket.com/albums/j3...o/HPIM1848.jpg
They get 9.75" of travel, compared to 6.5" ( I think on the f9000)
More hand made brackets
http://i83.photobucket.com/albums/j3...o/HPIM1834.jpg
http://i83.photobucket.com/albums/j3...o/HPIM1835.jpg
http://i83.photobucket.com/albums/j3...o/HPIM1837.jpg
Rear bag brackets complete
http://i83.photobucket.com/albums/j3...o/HPIM1844.jpg
Bag in
http://i83.photobucket.com/albums/j3...o/HPIM1849.jpg
Rear end being welded up
http://i83.photobucket.com/albums/j3...o/HPIM1853.jpg
GMracer 02-09-2009 12:53 PM
The edges arent smooth because there will be a shock mount in front of that shortly
http://i83.photobucket.com/albums/j3...o/HPIM1855.jpg
http://i83.photobucket.com/albums/j3...o/HPIM1857.jpg
http://i83.photobucket.com/albums/j3...o/HPIM1888.jpg
Stock way bar (shape) can be used, plan to run a muscle bar from ART
http://i83.photobucket.com/albums/j3...o/HPIM1863.jpg
Now before I flipped the frame I thought about any weak point and this one stood out to me, where I pie cut it, so I added a gusset, couldn't hurt
http://i83.photobucket.com/albums/j3...o/HPIM1870.jpg
GMracer 02-09-2009 12:54 PM
http://i83.photobucket.com/albums/j3...o/HPIM1875.jpg
Stripped
http://i83.photobucket.com/albums/j3...o/HPIM1878.jpg
Flipped
http://i83.photobucket.com/albums/j3...o/HPIM1889.jpg
Boxed in the LCA mounts
http://i83.photobucket.com/albums/j3...o/HPIM1890.jpg
http://i83.photobucket.com/albums/j3...o/HPIM1891.jpg
GMracer 02-09-2009 12:55 PM
http://i83.photobucket.com/albums/j3...o/HPIM1892.jpg
Welded up and smoothed the bottom side, Plan to DA it before Powder coat
http://i83.photobucket.com/albums/j3...o/HPIM1898.jpg
and the frame heads home...
Back in the garage, (before I organized my tools and such for more room)
http://i83.photobucket.com/albums/j3...o/HPIM1902.jpg
Money shot 3/4" from rocker, right where I want it
http://i83.photobucket.com/albums/j3...o/HPIM1904.jpg
http://i83.photobucket.com/albums/j3...o/HPIM1908.jpg
http://i83.photobucket.com/albums/j3...o/HPIM1909.jpg
http://i83.photobucket.com/albums/j3...o/HPIM1910.jpg
http://i83.photobucket.com/albums/j3...o/HPIM1911.jpg
http://i83.photobucket.com/albums/j3...o/HPIM1912.jpg
ScotI 02-09-2009 01:08 PM
Very nice. I might have missed where this was discussed, but did you invert the 4-bars for clearance w/the d.shaft (they're usually parallel on the bottom & angled @ the top)? What type welder are you utilizing?
GMracer 02-09-2009 01:44 PM
the bars are adjustable so and its not at ride height in the pics
lincoln 235 powermig
Ketzer 02-09-2009 03:06 PM
I have an airbag question... (those new bags look incredible btw)
Why do most folks run the sleeved type on the rear and the bellows type up front? Why not run bellows all around?
GMracer 02-09-2009 03:14 PM
They are freakin' awesome haha.
Bellow bags are designed to be used on a ratio setup, like the control arms will work the bag 2:1 or 1.5:1. Some guys will use bellows out back, but you typically mount them on a cantilever arm or even the 4 link bar itself, using the bag again in a ratio setup. Sleeves are designed for a 1:1 ration, and tend to ride better and have more control on ride feel with them.
I've seen guys run bellows 1:1 but they don't ride great, and loose lift.
WSSix 02-09-2009 03:14 PM
looks fantastic! Feels great to have the cab back on doesn't it? Now, how is the engine and transmission just balancing on the oil pan? Is the weight really that even or did you photochop the pics?
tones2SS 02-09-2009 03:24 PM
Looking great GMRACER!
You're making some real gains there. Amazing build bud.
Keep up the great work!!:thumbsup: :cheers:
GMracer 02-09-2009 03:47 PM
yep t56 is light, plus I'm not too worried about that motor it's just my spare 4.8L I'm not using. So it's just balancing, and yes it feels AWESOME to have it back on.
Thanks man!
tones2SS 02-09-2009 03:50 PM
"If" I ever get a chance, I should stop by and check it out.
It's nice to see the cab sitting on the frame as well.
GMracer 02-09-2009 04:08 PM
You should, whenever you want (weekends)
deuce_454 02-15-2009 01:23 PM
its called a satchel link.. the reason to do this instead of the GM-usual k link konfiguration is that it fixes the rollcenter in relation to teh center of gravity as the suspension moves thru its travel.. and at a lower point than the k-link. , the rollcenter of both the satchell and k link is at the intersection of the angled bars.. so with the k link it moves up and down more than the body does
in short its better for handling, but more difficult to package as it needs a sturdy crossmember below driveshaft level...
GMracer 02-23-2009 01:22 PM
Well I found a slight flex out back wanted to add another triangulated brace
http://i83.photobucket.com/albums/j3...o/Sch02224.jpg
http://i83.photobucket.com/albums/j3...o/Sch02225.jpg
Brand new, perfect condition bed...
http://i83.photobucket.com/albums/j3...o/Sch02227.jpg
Now all cut and section bed floor raised 5.5"
http://i83.photobucket.com/albums/j3.../Sch022210.jpg
http://i83.photobucket.com/albums/j3.../Sch022211.jpg
I didn't want to go more then 5.5" So to get the last >1" I'll section the bed crossmembers over the frame.
http://i83.photobucket.com/albums/j3.../Sch022212.jpg
Cut the firewall and trans tunnel out to accommodate the motor, (body dropped 2", motor raised 1" and moved back 1.5"
http://i83.photobucket.com/albums/j3.../Sch022215.jpg
Motor view, looks pretty far back without any accessories on it
http://i83.photobucket.com/albums/j3.../Sch022217.jpg
http://i83.photobucket.com/albums/j3.../Sch022218.jpg
Got my hubs from Moser Friday, should have my axles this coming Friday
5x5 lug pattern, 1/2"x120 screw in studs
http://i83.photobucket.com/albums/j3.../Sch022225.jpg
tones2SS 02-23-2009 03:36 PM
NICE!!!
It's getting there man.:thumbsup:
novaboy7272 02-23-2009 06:13 PM
that build is looking to be insane. I can't wait to see it in the end. Great job. :wow:
Datsbad 02-23-2009 08:19 PM
I am really liking this truck , keep up the good work .
GMracer 02-23-2009 08:24 PM
thanks, I'm starting to like it again too :willy:
Kenny_Cox 02-23-2009 08:32 PM
11 pages later and i am impressed.:hail:
everything looks beautiful.
srh3trinity 02-23-2009 09:10 PM
Amazing, that truck is going to be awesome when it's finished.
GMracer 02-24-2009 04:25 AM
thanks guys, I really appreciate the kind words
GMracer 03-02-2009 06:33 AM
First of all big thanks to Marty, owner of the incredible http://www.syborgtwinturbo.com/ Big help in letting me use his wheel tool. Made it so easy to measure and check clearances.
http://i83.photobucket.com/albums/j3.../030109005.jpg
I did however notice my wheel wasnt perfectly centered in the wheel well, and that pisses me off, however I'll be able to adjust it once I get the bed permanently mounted I'll figure out just how much I'm off.
http://i83.photobucket.com/albums/j3.../030109004.jpg
Cut out for the tubs, still looking for a spare set of factory tubs if anyone has any laying around. Basically I want to mimic the factory just 6" wider.
http://i83.photobucket.com/albums/j3.../030109006.jpg
One thing I hate is when people run big wheels, or such and the tires and wheel are soo tucked in leaving a huge gap between the bedside and tire, even though sometimes it requires that to fit way up top. I kept it tight, here you can kind of see the tire just touches that lip, well I plan to roll that edge so the wheel will be pretty close to the actual bedside. Laid out I still have a fingers gap up top against the bedside
http://i83.photobucket.com/albums/j3.../030109007.jpg
Just a quick undershot
http://i83.photobucket.com/albums/j3.../030109010.jpg
GMracer 03-02-2009 06:34 AM
http://i83.photobucket.com/albums/j3.../030109011.jpg
Measuring for backspacing
http://i83.photobucket.com/albums/j3.../030109017.jpg
Moving up front
http://i83.photobucket.com/albums/j3.../030109013.jpg
http://i83.photobucket.com/albums/j3.../030109014.jpg
Mounted the tire
http://i83.photobucket.com/albums/j3.../030109018.jpg
GMracer 03-02-2009 06:35 AM
This is set at ride height
http://i83.photobucket.com/albums/j3.../030109019.jpg
http://i83.photobucket.com/albums/j3.../030109020.jpg
Lock to lock
http://i83.photobucket.com/albums/j3.../030109021.jpg
http://i83.photobucket.com/albums/j3.../030109024.jpg
http://i83.photobucket.com/albums/j3.../030109025.jpg
http://i83.photobucket.com/albums/j3.../030109026.jpg
http://i83.photobucket.com/albums/j3.../030109028.jpg
Almost laid out, need to trim some more.
http://i83.photobucket.com/albums/j3.../030109031.jpg
http://i83.photobucket.com/albums/j3.../030109033.jpg
novaboy7272 03-02-2009 07:44 AM
Hey the build is looking insane just to tell you. But i was wondering if you know where i can get that tool for lining up your rear tire in the fenderwell off the differential? Thank man, i appreciate it. Good luck with the rest of the build, lookin forward to see it hit the road. :woot:
GMracer 03-02-2009 09:07 AM
PM Syborg
