| Roadster Shop |
07-16-2012 03:27 PM |
Originally Posted by Sieg
(Post 424223)
Good stuff Chris :thumbsup:
Trucks are posting numbers, can I assume partially due to weight and weight bias?
The weight bias is actually a disadvantage. We ended up adding almost 200 lbs and a larger gas tank to the back of the truck in order to get closer to a 50/50 weight distribution. The truck tips the scales around 3,600 lbs so it is no lightweight.
Originally Posted by GRob
(Post 424657)
I think the enormous tires under it would be one of the main factors.
They are wide vehicles to begin with so there is a lot of room for tires. We are running a 345 front and rear with out any body mods (except for mini tubs and removing the inner fenders.
Originally Posted by Chafin
(Post 425030)
Thanks for the info, but I don't think they will offer the tire clearance that we need. We will eventually fab something for the truck when time allows.
