-   -   question for turbo experts (https://www.lateral-g.net/forums/showthread.php?t=15526)
sniper 07-05-2008 12:33 PM
Originally Posted by camcojb (Post 155438)
thought of that too, but it's just one more thing to fail (with my luck......... :willy: ). The drain is above the oil level, I've run the engine with the line disconnected at the pan, and draining into a bucket, and nothing comes out of the pan.
Missed that earlier.
Originally Posted by camcojb (Post 155456)
I have 35 psi hot at idle. Both turbos feed off the same line, which is tee'd in the center to feed them. My latest thought, for what it's worth, is that the 90 degree fitting on the outlet (required due to frame clearance issues) is too upright of an angle. In other words the fitting comes almost straight down off the turbo and then is almost horizontal at the end of the bend. The other side has the center section clocked differently so that it's app. a 45 degree angle off the turbo to the outside of the car, then turns 90 degrees to be 45 degrees down again towards the oil pan. This is the only difference in the two sides, identical fittings, line sizes, etc. My thought is that this could be the difference in flow backing up, because when I ran the car with the drain line running into the bucket I was surprised how much flow comes out of that line, considering it's reduced to only a .035" hole on the inlet fitting.
The next step will be to find an inline regulator of some sort to reduce the oil pressure at the turbo. I'm told the ball bearing turbos only need 5-9 psi at the turbo, and I'm way past that.
Can you clerify the bold statements? You say you had no flow and then you have flow? What was the difference between the two scenarios, the 90?
Also I have always pulled from a low pressure source to feed a turbo, becasue of the isssue of blowin seal.
One more question if I may, do the returns from each turbo merge, or do they have their own return fitting on the oil pan?
Originally Posted by badmatt (Post 155457)
maybe the seals are already toast... but they shouldnt be..
With the speeds that a tubine spins, even at idle, that friction with no oil can burn up the seals real quick.
I was looking at the motor on your website, man that is sick. It looked like both oil returns were clocked to about the 4 or 5 position, is that correct?
camcojb 07-05-2008 12:37 PM
Jody if it were me id start playing with the drain size of the pan I still think that has somehting todo with the smoke but thats me.
yeah, but disconnecting the line at the pan did not stop the smoke. Or do you mena a larger drain line? Thing is 5/8" i.d. is plenty big according to pretty much everyone. That's what was on here with the old motor too I believe.
camcojb 07-05-2008 12:41 PM
No flow was the return line disconnected at the pan, no flow from the pan fitting. That means the fitting is not below the oil level in the pan, and there isn't any pressure inside at idle from whipping oil, as nothing came out of the fitting, I did not cap it.
The flow that surprised was the actual drain line off the turbo emptying into a bucket; quite a bit more oil than I expected to see.
Oil lines are separate, one into the front side of the pan, one at each side. The passenger side drain line is clocked at about 7:30-8 o'clock, the drivers side is between 5 and 6, more vertical.
I do not know of a low pressure area to pull the oil from; this is a fitting on the oil pan provided by ATS for an oil feed or pressure gauge.
badmatt 07-05-2008 12:54 PM
I use a single -16 (3/4") when i test fired my motor and had no oil problems but your running a small frame turbo and im running a large frame. so there is some differences
If it were me id up grade to a larger line.
Oh BTW jody i went and picked up the paint!
camcojb 07-05-2008 01:03 PM
cool.......... :thumbsup: Orange???
J2SpeedandCustom 07-05-2008 02:17 PM
Jody don't worry about the pressure going into the turbo. Lots of cars out there with way more than 35psi of oil pressure into the turbo. What sucks is that you need a 90 to drain of the turbo. I bet it you can get that as straight as possible the smoke will go away. Glad to hear the motor isn't the problem! :thumbsup:
So when do we get to see video of the beast on the road???
Vegas69 07-05-2008 02:38 PM
If it was a drainage problem then I would think it would smoke while driving not at idle. Also both sides would smoke because they have the same drain size. I bet if you rotate that turbo to match the non problematic side it fixes your problem. No turbo expert but that side works and everything else is the same.
badmatt 07-05-2008 02:54 PM
yep :)
chevyIIpost 07-05-2008 04:00 PM
Did you catch my fuel preasure regulator suggestion as a tempory test for adjusting oil feed preasure/flow?
If repositioning the drain fitting to make the angle the same is resonably easy I would go there first. But the assumtion that is still bothering me is the Turbo having a fresh seal. It took FOUR prochargers on one of the projects I was building at Hot Rod Garage before we got a low boost/noise problem fixed. They repaired 3 of them and we finally told them we wanted a new unit because that is what the customer purchased and no more repaired units. That fixed it. If it failed ounce and there wasn't a completely obvious problem they still may not have found the original issue i.e. something machined wrong or some run out issue. I have fought this more than once.
Can you put a temporary drain hose with a rubber line and staight fitting in place of the 90 fitting as a test?
If you can't come up with a regulator can you put a smaller orfice in place to reduce the flow to the turbo?
It may be a combination issue, marginally high flow, marginal drain fitting/angle, and marginal turbo seal.
IMO just food for thought.
camcojb 07-05-2008 04:13 PM
good thoughts. I already re-clocked the turbo. Just have to add coolant and attach the lower drain fitting and it's done. I'll let you know how it goes................. :)
