If you're going to go stock subframe there are a few ways to approach it. Cheap - Tall ball joints or guldstrand mod, new shocks and springs, some form of a-arm upgrade (upper adjustable and stock lower), sway bar and steering upgrades. Medium - Tall spindles, new adjustable shocks and springs, sway bar, new a-arms. More - The above plus double adjustable shocks or coil-over conversion or more extreme changes. I don't have the perception that there is a huge gap between one option and the next. The biggest gap is from stock to any upgrade, and then things get incrementally better or more adjustable. I'm going with the medium cost option and expect it to be competitive having spent a lot of time reading about components and piecing them together to make a good whole. That's one of the bigger tangible benefits with the aftermarket subframes, in that you can just order it and all of the pieces work together without you having to do much thinking. Brake wise I have AFX spindles so I just went C5 brakes which are cheap, have lots of pad options and aren't uncommon on track cars. I intend to leave the option on the table to upgrade to C6 ZO6 brakes in case I need to, |
I agree that going with the full sub upgrade is a no-brainer approach to a decent setup - at a cost. You have obviously been researching this longer then I have, care to share the setup you have decided to go with? One thing I have discovered with the brake setup is that it will cost about $400 more on the stock spindle then the ATS spindle because you need a new hub and brackets. This narrows the price gap between the stock spindle and AFX spindle enough (in my book) to upgrade. |
I'm doing "More" and then some for my project '68 - 21st Century Street Machine subframe, Lateral Dynamics 3 link rear, and so on. If you do the work yourself, and part select yourself, don't let anyone tell you it's a no brainer. I've spent 2 or more hours planning for every hour actually working on the car. Finally, I'm planning/assembling parts for "Medium" for my project '67 - SC&C (SPC) UCA/LCA, ATS tall spindles, AFCO spring adjusters and AFCO springs, Hotchkis sway bar, Bilstein shocks, 3rd generation IROC steering box, etc. Of the three, "Medium" so far seems easier than either "Cheap" or "More" because it's pretty much a bolt on and go as compared to the other two; but then again, I'm much more knowledgeable now than I was when I started on "Cheap." |
here is my setup... OEM subframe + reweld, ATS coilover brackets.. I found here "used" which means just taken out of box ... for a steal... ATS tall spindles, SC&C arms.
Point is don't box your self in... if your not in a rush you can get what you want if you watch the classifieds.. |
My subframe plan right now includes the following parts most of which I have: AFX tall spindles - Had these for a long time now SC&C adjustable upper arms (not the lite ones sadly) Hotchkis sway bar - Probably my least researched item Detroit speed lower arms Varishock single adjustable shocks Detroit speed 2" drop coil springs - Any brand would probably work fine DSE or Speedtech steering box - Have not gotten this yet. C5 brakes - Cheap and effective. In an effort to lighten it and to make it stronger, it has some other modifications, mostly replacing the front crossmember and re-welding. |
Thanks :cheers: |
AFX SC&C UCA not sure about sway but I would like adjustable, hollow to save some lbs LCA, not sure as I need a coilover lower full coilover, I will make my own top mount steering box? brakes, If C5's will get the job done - Great as they are about half the price of the Z06. add some front struts Looks like I'm getting it nailed down, Thanks for your help gents :cheers: |
just to answer.. the crossshaft is steel, the lightweight arm uses steel on hardened steel as bearing instead of bushing.. the non lightweight arms uses a high durometer rubber.. needless to say i got the steel on steel type... less friction, and no rubber to rot (just grease it once in a while)
| All times are GMT -7. The time now is 04:44 PM. |
