-   -   If you had 10k to spend? (https://www.lateral-g.net/forums/showthread.php?t=44383)
V8TV 01-04-2014 01:57 PM
Lots of good suggestions.
If it were me, I'd do:
- Hydroboost
- Global West Del-A-Lum bushings in front suspension, subframe, rear leaf springs
- Subframe connectors (don't recall if you had them)
- Some form of spring / shock upgrade, possibly coil-overs in front
- Good sway bars
- Tilt column
- Change A/N fittings to black, maybe move the regulator
- Change the coolflex hoses, gates clamps all around
- Vintage Air
- Seats / Belts (don't know what you have, but good seats make a HUGE difference
- Upsize the wheels / lower profile tires, keep the vintage look, Rockets make good low-buck retro wheels
Thank that would fit in $10k?
chichirone 01-04-2014 02:28 PM
Originally Posted by Rod P (Post 524398)
put a complete Ridetech level 2 coil over suspension kit on it! that's 4000.00 bucks of the 10 gs car will drive 10 times better, spend a little on new wheels and tires to go on those new disc brakes, and with the left over funds, take a driving school :thumbsup:
Agree with this 100%! :G-Dub:
rickpaw 01-06-2014 04:05 AM
Great suggestions so far. I'll throw in my $0.02.
-If you have $$$ left over from the guys' suggestions, add AC since you're from Tx, and if you're planning to drive the car more often.
