-   -   1963 AMC Rambler Classic (https://www.lateral-g.net/forums/showthread.php?t=51815)
63RamblerClassic 01-08-2016 08:43 AM
Here are the width specs: Overall width is 45-1/8". 15-1/2" mount centers.
The year T-Bird it's from is 1982-88.
63RamblerClassic 01-28-2016 06:41 AM
Update without images.
So, a lot has happened since I last posted. We are teaming up with Wilwood Brakes on the build! The front end is being mocked up and installed this weekend. The rear end is also being mocked up this weekend. Custom axles have arrived from Moser, the Ford 9" has been narrowed, the ridetech 4 link is ready to roll. Center section is going to be an Auburn Posi unit with a 3.73 gear. That is getting picked up tonight.
The ride height has officially been set.
Also, the Ididit steering column has just arrived. Since the build is an automatic and I did not want to place a large console in the floor, we are utilizing a column shifter.
Here are the Wilwood components that are on their way:
http://www.wilwood.com/BrakeKits/Bra...mno=140-9802-D
http://www.wilwood.com/LineKits/Line...temno=220-8307
http://www.wilwood.com/BrakeKits/Bra...no=140-10012-D
http://www.wilwood.com/Hardware/Hard...temno=330-9371
http://www.wilwood.com/MasterCylinde...o=261-13270-BK
http://www.wilwood.com/BrakeFluid/Br...temno=290-2210
More pictures and videos are coming this weekend!
63RamblerClassic 02-01-2016 08:08 AM
This weekend we got a good amount accomplished on the car. The differential got finished and installed (3.75 Roush/Fenway Trac-Lok Posi Diff with polished gears), we centered the axle, cut out a portion of the trunk, mounted the upper shock mount bar, Brian welded the 4 link hardware to the 9” and to the chassis, and installed the parallel 4 link bars. Front suspension has already been mocked up on the floor.
Tonight the front shock towers get cut out to make some space. The front cross-member is going to be welded in later this week (as soon as the brakes arrive to confirm clearances). Brian hopes the car will be rolling with a suspension and working steering within 2 weeks.
And I found an NOS grille for the car for a decent price.
A small video of the work: https://www.youtube.com/watch?v=AvNCVsnhxgA .
https://farm2.staticflickr.com/1473/...daf77b29_b.jpgIMG_09641 by kcoxphoto, on Flickr
https://farm2.staticflickr.com/1518/...9ddf9ec2_b.jpgIMG_09651 by kcoxphoto, on Flickr
https://farm2.staticflickr.com/1582/...14ac7677_b.jpgIMG_09661 by kcoxphoto, on Flickr
https://farm2.staticflickr.com/1457/...b6e6c323_b.jpgIMG_11271 by kcoxphoto, on Flickr
https://farm2.staticflickr.com/1604/...2c5e418a_b.jpgIMG_11301 by kcoxphoto, on Flickr
https://farm2.staticflickr.com/1690/...e3401b4d_b.jpgIMG_11371 by kcoxphoto, on Flickr
https://farm2.staticflickr.com/1468/...88ecf46e_b.jpgIMG_11391 by kcoxphoto, on Flickr
https://farm2.staticflickr.com/1713/...6089b330_b.jpgIMG_11441 by kcoxphoto, on Flickr
https://farm2.staticflickr.com/1555/...d19acc96_b.jpgVZM.IMG_20160114_1707461 by kcoxphoto, on Flickr
SlowProgress 02-01-2016 01:33 PM
Nice project and its not a Camaro which is so cool. You move fast!
fearlessmark 02-01-2016 02:09 PM
Neat little project you have going there!
Graham08 02-02-2016 08:08 AM
Cool project! I really like the non-traditional body style. It looks like roughly the same size car as a Chevy II, so I'm guessing it's nice and light.
63RamblerClassic 02-02-2016 09:00 AM
Thanks, and yes it is moderately light by some folks standards. It weighed 2800 before we starting tearing it apart. We aim to keep it around 2800-2900 lbs with the LS. The original iron 6 cylinder was HEAVY.
WSSix 02-03-2016 11:45 AM
Some how I've missed this build until now. I love it! You're doing great work so far. Good luck!
63RamblerClassic 02-04-2016 05:23 AM
Brian at http://www.utpracecars.com welded in the Heidts Mustang II front Cross-Member and mounted the control arms so we could determine how the wheel would turn within the front fender wells.
Here are some progress pics and some welding pics of Brian.
Wilwood Brakes should be here next week.
https://farm2.staticflickr.com/1651/...3ecf7cb9_b.jpgIMG_1475 by kcoxphoto, on Flickr
https://farm2.staticflickr.com/1644/...2f9c6a1f_b.jpgIMG_1492 by kcoxphoto, on Flickr
https://farm2.staticflickr.com/1674/...ddb44872_b.jpgIMG_1511 by kcoxphoto, on Flickr
https://farm2.staticflickr.com/1495/...f264bd70_b.jpgIMG_1520 by kcoxphoto, on Flickr
https://farm2.staticflickr.com/1599/...73b6cd7f_b.jpgIMG_1526 by kcoxphoto, on Flickr
https://farm2.staticflickr.com/1445/...a00432e6_b.jpgIMG_1530 by kcoxphoto, on Flickr
https://farm2.staticflickr.com/1677/...3bc04616_b.jpgIMG_1534 by kcoxphoto, on Flickr
https://farm2.staticflickr.com/1693/...00cd8b21_b.jpgIMG_1537 by kcoxphoto, on Flickr
63RamblerClassic 02-09-2016 08:27 AM
Just curious what sort of brake pedal setups you guys are running?
Also what are you using for pressure: Hydroboost or traditional vacuum booster?
