As long as your TA is and I assume it is 6 to 8 inches at the front at ride height, your wheel hop is probably coming from shock dampening and spring rate if I were to guess.
Where is your watts piviot in relationship to axle centerline?
Thanks again Payton. |
With it above center line you have raised the roll center and loosened the rear. The lower you go the more bite you will have in the rear. Try an inch or 2 below axle centerline. Is your watts fixed or adjustable? I assume your rear trailing arms are level at ride height
And Watts Link has a lot of adjustment. Thanks. |
I was not speaking about the front mount. I would guess it is 6 to 8 inches from the ground at ride height. I am speaking of the watts pivot in relation to your axle centerline at ride height. The lower the pivot the more bite you will have up to a point. I would start it at or 1 inch below axle centerline and start messing with the shocks.
Increasing the rebound valving like you stated earlier would help as well. |
Tell me it isn't so...are we going to lose Heartland to the city of Topeka for not paying their bills? I hope they keep it open. If not that puts my closest track with Elkhart. Frustrated.
You mentioned this picture was at the "suggested" ride height. Can you tell me what that is or where you got the info? Is it a specific measurement somewhere?
I got my wheels in and I'm trying to get camber set close to -0.5 to -1.0 as suggested so i can see what kind of work I might need to do to inner/outer fenders. thanks (sorry couldn't figure out how to copy the picture you had attached for reference) Quote:
For the front, on my car with 1" drop spindles, it placed the front body line at roughly 24 1/4" to the ground. I built a 1" rake into the car so the back body line is at 25 1//4". But if I were you I would call them as they may have changed things up a little and using my body line measurements would not be very accurate. David |
You mentioned you went with -1.5 camber, +6 caster, and I think +1/8 toe and it was recommended by Rod. How is your tire wear with that setup? It seems that would be more for autocross rather than street. Any thoughts or changes you are considering? thanks, Jake |
David |
Jake,
Below is the email conversion about setting ride height per Josh at Ridetech. But again you better make sure they haven't changed their shocks. They may have added more stroke to the shock. "Hey David, Thanks alot, we appreciate it! On the front, your shock, from eye to stud mount (the hole in the pocket) will be 12.75"~. On the rear, from center to center on the mounting bolts will be right around 14.5". That is where the shocks will have their best ride quality/performance. I will have to check on the engine mounts, I know we used the Holley oil pan, but for some reason I'm thinking we used a GM style engine mount. Thanks, Josh" Quote:
I'll have to figure out how to measure the 12.75" as you can't really put a tape measure down from the hole mount due to the inflated airbag. I should be able to at least get in a reasonable distance to start fitting the inner fender and figuring out how I want to modify. |
thanks, Jake |
I sure don't. I've never had it high enough to get pictures of the underside. You might check with Payton King or one of the other guys. I use to have some good pictures of Dead Cat but I've must have lost them or deleted them. I can say that 18X12s with a 6" bs and a rear with a 55.5" wms to wms worked for me. My rear is actually 54" wms to wms but I am using 3/4" spacers on both sides to keep the spindle under the center caps on the wheels. Me rear is a floater. The only alternative for me would've been to add that 3/4" to each wheel center thickness when they were made. David |
[IMG]http://i1309.photobucket.com/albums/...psr0h6v2qp.jpg[/IMG] I'm just trying to figure out how close to the outside fender I can get without rubbing not only during driving but also when setting the AirRide completely down as I noticed the inner rear fender actually bulges in ward a little before going up and curving over. Based on your 55.5" WMS to WMS (including spacers) and your 12" wheel widths and 6" BS, it should measure outside to outside of the tires very much the same as my rough measurements I got last night in my first attempt to measure my WMS to WMS. I came up with roughly 54.5" but my wheels are 11.5" wide and have a 5" BS. The spacing between the outside fender lip is the pic I attached above. I'm measuring out to get a shortened rear end built and I'm also planning on going with a floater. I have more than enough room on the inside fender to inner wheel as its probably closer to 1 1/2" there. I'm just trying to set them as far out to the outside as possible so they don't look set in to the wheel well too far. |
1 Attachment(s)
1 Attachment(s)
And this one.....
10 Attachment(s)
I apologize for not posting results in so long but my father passed from a tough bout with cancer in October and that along with another family crisis I just haven't felt like browsing forums.
At this time I can report that I've finished up my TA suspension (although I've decided I do need to put it on a diet), installed a new floor pan, a new fuel system end to end for the LS, installed the LS and T56 with the Holley system (mounts, long tube headers, cross member that I altered to accommodate the front mount of the TA, and HP EFI). I'm now in the process of setting up the DSE dash insert with custom Speed Hut gauges, adding the Vintage air Gen IV, finally installing the Ridetech AirRide compressor system (placing a 3 gal tank in the pockets at rear of quarters on both sides, been using simple valves to add air up to this point). I'll add pictures of this process when I can collect them from my shop camera. Made my first trip to mom's on Christmas and can say I really like the LS platform! Its been a joy to drive as long as I stay away from parking lots. I've lost a lot of turning radius with the Ridetech Tru Turn system. Slowly trying to sort through that issue. At this time, I imagine my only option is to move the Muscle Bar rearward on the frame to allow more turn radius and maybe notch the frame as needed at the rear. As others have noticed, my front wheels are well behind the center line of the wheel opening, which is causing the rear of the front tires to rub on the inner fender well during turning. I fear that Ridetech may have sent me the wrong control arms. At this time my specs are as follows: Ridetech Tru Turn system complete with TQ Airsprings and Muscle Bars 18X9.5 True Forged Competitions with 5.75" bs 275/35/18's +5 Caster -1.5 Camber 1/16" toe in Kore 3 C6 ZO6 hubs/rotors Stock Height Frame bushings Stock Subframe |
10 Attachment(s)
A few more updates
What power steering hoses are those? They look great.
Don |
They are from "Gotta Show". Very nice product but in the end I was unable to resolve a poor seal at the steering box. I have instead gone with adapters to AN hose. I was unable to tighten their fitting enough to eliminate the leak without pulling threads on their fitting eventually. I was able to keep my new Delphi 670 and with adaptors and AN hose eliminate the leak all together.
If you guys are using an OEM box it should be a non issue for you. Tom Lee altered a new Delphi 670 to work with OEM hoses by using one of his adaptors, which raises the sealing surface in the port, not allowing enough thread engagement. Had I not altered the 670 and had Gotta Show make metric ends I would've been fine. No ones fault on either side, just wouldn't work out the way I was using it. |
1 Attachment(s)
I should make mention for those who still wish to use the Ridetech Tru Turn system and stuff a 275/35/18 in their wheel house, this is basically what I have done to get the clearances inside the wheel house. It is very crude, and still incomplete to this day but it does function and I'll get around to finish welding, cleaning up, and sealing it proper eventually. lol
Everything I have done so far is for a driving mock up. I have plans of installing a new crate LS3 later and have decided to ditch the twin turbos and the Maggy for a Pro Charger. Man I love the power curve on the DS1's.
1 Attachment(s)
Most recent update. I've been driving the car a lot more and I'm really enjoying it. Probably just enjoy the car for a year or two, and tear it down for a proper restore.
1 Attachment(s)
At ride height.
1 Attachment(s)
Speedhuts/DSE complete. Much better gauge arrangement. I can actually see everything now.
1 Attachment(s)
Really wanted to countersink the gauges. Maybe later.
| All times are GMT -7. The time now is 06:19 AM. |
