-   -   Project 'Overtime': Pro-Touring 68 Acadian (Nova) with L92 swap (https://www.lateral-g.net/forums/showthread.php?t=14349)
70rs 09-14-2011 02:18 PM
Looks great Mike.
Those gaskets should be there by now. If they don't show today please let me know.
waynieZ 09-15-2011 01:28 PM
Great looking rendering.
andrew5 09-15-2011 04:20 PM
that rendering is sweet!!!!! :cheers:
scherp69 09-15-2011 05:41 PM
Originally Posted by GregWeld (Post 369810)
Great looking Mike!
I too, had a new roof and paint done this summer... sure made a big difference.
Thanks Greg. Yes it's amazing what a couple coats of paint can do.
Originally Posted by LanceL (Post 369811)
Mike, that looks great!!! Like it
Originally Posted by frojoe (Post 369820)
DUDE. So uncool.
I'm so jealous.
Looks fantastic.
Originally Posted by 70rs (Post 369839)
Looks great Mike.
Thanks guys. I'm very happy with the way the rendering turned out.
Well the cam degree kit and the head gaskets both arrived today. I decided to head out to the shop and take another shot at degreeing the cam. It's actually not so bad when you have the proper equipment.
So here's the degree kit I got. It's a LS specific kit and is Comp Cams part number 4942. Here's how it comes:
http://i222.photobucket.com/albums/d...9/P1010246.jpg
And here's what's included:
http://i222.photobucket.com/albums/d...9/P1010247.jpg
First thing I did when I got out to the shop was to hang up some inspiration. I plan on getting a blown up print done and framing it. It will also hang in the shop.
http://i222.photobucket.com/albums/d...9/P1010244.jpg
A couple guys on the forums brought it to my attention that I didn't put any assembly lube on the bearing portion of the cam. So while it was still easy to get at, I pulled the cam out and put some more lube on.
http://i222.photobucket.com/albums/d...9/P1010248.jpg
Put it back together with the new LS2 timing chain dampner.
http://i222.photobucket.com/albums/d...9/P1010250.jpg
Then it was time to degree the cam. I found a really good website that shows step by step how to degree a cam using the same kit I have. It looks like it was done by Car Craft Magazine. Was very useful: http://xtremecarzone.com.au/lofivers....php?t805.html
Here's another website that I found very helpful for replacing the cam shaft: http://www.camaro5.com/forums/showthread.php?t=125123
One more site I found very useful was: http://ls1howto.com/ It has all the bolt torque ratings for the entire engine as well as several other good articles.
First thing I put on was the crank socket. This thing works really well and sure makes turning the crank over a breeze.
http://i222.photobucket.com/albums/d...9/P1010251.jpg
At the end of the socket, there is a threaded part where the degree wheel goes. Very easy to adjust. Loosen the nut, move the wheel and tighten it back up.
http://i222.photobucket.com/albums/d...9/P1010252.jpg
Uses a half inch wratchet
http://i222.photobucket.com/albums/d...9/P1010254.jpg
Degree wheel on. I didn't take a picture with the pointer in place, but I mounted it with a bolt to the hole just to the upper right of the wheel. You bend the piece of copper that's included with the kit to 90 degrees to make a pointer.
http://i222.photobucket.com/albums/d...9/P1010255.jpg
I'm not going to repeat what the step by step article says (if you're going to degree your cam, well worth reading it. I even took my laptop out to the shop and followed it) but here's a pic of the piston stop in place.
http://i222.photobucket.com/albums/d...9/P1010256.jpg
The dial indicator with in place. They include a couple different size ends for where it screws into the block.
http://i222.photobucket.com/albums/d...9/P1010262.jpg
So after following the step by step instructions on the website I posted, I came up with 71 degrees before max lift and 154 degrees after max lift. That gave me a lobe centre angle of 112.5. I compared that to the lobe centre angle on my cam specs. It should be 112. I'm happy with that. Unless someone tells me that I shouldn't be. I checked the numbers about 5 times and came up with the same results each time.
I go back to work tomorrow so won't get chance to get back into the shop until Tuesday or Wednesday. I also ordered a new oil pan gasket, timing cover gasket and front seal today. Next week I should have the engine back together and will hopefully get it back into the car (hopefully for good....again).
Here's a couple other parts that I got over the last couple weeks:
Complete hinge rebuild from Classic Industries:
http://i222.photobucket.com/albums/d...9/P1010243.jpg
Close out covers for the firewall. They will cover up the ugly subframe bolt openings. I have them on, but forgot to take a pic. They really clean up the firewall. Got these from Mike at http://musclerodz.com/
http://i222.photobucket.com/albums/d...9/P1010242.jpg
scherp69 09-15-2011 05:42 PM
I mentioned that we painted the house and shop last month. Thought I'd post some before and after pics:
House before:
http://i222.photobucket.com/albums/d...ICT00282-1.jpg
After:
http://i222.photobucket.com/albums/d...9/P1010220.jpg
Shop before:
http://i222.photobucket.com/albums/d...9/P1010221.jpg
After:
http://i222.photobucket.com/albums/d...9/P1010266.jpg
waynieZ 09-15-2011 06:33 PM
Wow your a busy guy. I'm glad someone caught the no lube on the bearings, no use taking a chance. Your doing a great job on the car.
70rs 09-15-2011 07:01 PM
Hey Mike, you missed a spot on the side of the shop.:D
GregWeld 09-15-2011 08:08 PM
Looks great Mike!
jschaecher 09-16-2011 07:22 AM
Mike outstanding as always.... who did your rendering?
scherp69 09-18-2011 09:16 AM
Thanks Wayne. Yeah and I'm not sure why I didn't put any one the first time. One of those oversights. I'm just glad it was so easy to pull the cam back out.
yeah yeah yeah :D
Originally Posted by GregWeld (Post 370006)
Looks great Mike!
Thanks Greg.
Thanks. It was Shawn Mascoll. His website is www.mascolldesigns.com
