-   -   The Most Detailed LS3 In The Universe! (https://www.lateral-g.net/forums/showthread.php?t=38904)
Al Moreno 10-18-2015 08:13 AM
Interior work:
Since the car is now a none AC/radio, the idea was to remove any GM hint that it ever came with these features.
Radio and AC face plate mods: The idea was to clean up the face plate and give it a floating effect.
To give it that effect, the face plate mounting points were cut off.
http://i1231.photobucket.com/albums/...pshxm7psuu.jpg
Next, all the AC and radio control were shaved
http://i1231.photobucket.com/albums/...psi2xpsujz.jpg
Glass the backside and did some rough sanding.
http://i1231.photobucket.com/albums/...ps83hj4uo6.jpg
http://i1231.photobucket.com/albums/...psfcg3vq6e.jpg
Prep the dash for the floating effect by cutting off the mounting points
http://i1231.photobucket.com/albums/...psknsgwytq.jpg
http://i1231.photobucket.com/albums/...psxgg6q9wz.jpg
To finish the floating effect, we cut off the side bars from the dash sub structure.
http://i1231.photobucket.com/albums/...pstcyxlarr.jpg
Also remove the pieces on the side of the trans tunnel. Now we will be able to finish off the flooring material all the way to the fire wall which I think will give it a much nicer look.
http://i1231.photobucket.com/albums/...psw9spn2ry.jpg
http://i1231.photobucket.com/albums/...psle4cefb2.jpg
http://i1231.photobucket.com/albums/...ps4rztzsxz.jpg
http://i1231.photobucket.com/albums/...psr7h91jqj.jpg
http://i1231.photobucket.com/albums/...psohuuojv6.jpg
http://i1231.photobucket.com/albums/...psr27emujd.jpg
Al Moreno 10-18-2015 08:42 AM
Interior trunk divider
http://i1231.photobucket.com/albums/...psjubmjg2m.jpg
Door panels have been modified. we removed the storage pocket, speaker grille and continued the panel line to the edge. The AC vent was also filled (Not seen in this picture).
http://i1231.photobucket.com/albums/...psdngutbuk.jpg
http://i1231.photobucket.com/albums/...psp1rce6hh.jpg
Here is the AC vent on the door panel being filled by plastic welding a piece in.
http://i1231.photobucket.com/albums/...pslj53lxfp.jpg
The dash had over 20 mods at last count.
http://i1231.photobucket.com/albums/...psiml3i3jf.jpg
http://i1231.photobucket.com/albums/...psbvjawtx9.jpg
http://i1231.photobucket.com/albums/...pssyjzrphe.jpg
http://i1231.photobucket.com/albums/...ps1ftbric9.jpg
The speaker and defrost vents have been shaved.
http://i1231.photobucket.com/albums/...psr74ydbjy.jpg
http://i1231.photobucket.com/albums/...ps27jpgnvu.jpg
http://i1231.photobucket.com/albums/...psanfuygri.jpg
http://i1231.photobucket.com/albums/...psg4qawdxd.jpg
http://i1231.photobucket.com/albums/...psiqy472y3.jpg
http://i1231.photobucket.com/albums/...ps41hhwxoo.jpg
Al Moreno 10-18-2015 08:50 AM
Roll cage being painted.
http://i1231.photobucket.com/albums/...pssvks6ozn.jpg
http://i1231.photobucket.com/albums/...psjzibe33d.jpg
Replaced all the GM electronics. The gray box is Racepak's Smartwire which replaces all the fuse box and relays, plus it controls all the body functions. Its a really cool piece. It also cut down your wiring to about half. The red box is a mock up of Racepak’s G2X Data logger. The black box is Holley's Dominator EFI ECU.
http://i1231.photobucket.com/albums/...ps3igicmje.jpg
Modifying the CF Z28 diffuser with an aluminum tunnel.
http://i1231.photobucket.com/albums/...psujqhtgjn.jpg
http://i1231.photobucket.com/albums/...psavob8yey.jpg
Every line was replaced with stainless hard lines
http://i1231.photobucket.com/albums/...pssfx1ni1i.jpg
Suspension work:
http://i1231.photobucket.com/albums/...psr6ue3k7n.jpg
http://i1231.photobucket.com/albums/...psm7ruvmy9.jpg
http://i1231.photobucket.com/albums/...psyjmlssht.jpg
Made our own end links
http://i1231.photobucket.com/albums/...ps18yvvtdz.jpg
http://i1231.photobucket.com/albums/...pse4imbyxe.jpg
http://i1231.photobucket.com/albums/...pscb2cni8p.jpg
All the bolts on the Stop Tech Brakes were nickle plated. The little struts in the pictures are Racepak ride height sensors.
http://i1231.photobucket.com/albums/...psme97ahsw.jpg
Al Moreno 10-18-2015 08:55 AM
More of Dan great work!
http://i1231.photobucket.com/albums/...psbih6jimt.jpg
http://i1231.photobucket.com/albums/...psgbik3klt.jpg
http://i1231.photobucket.com/albums/...psulzouffb.jpg
One of three fire suppressant nozzle
http://i1231.photobucket.com/albums/...ps0b1m0api.jpg
glassman 10-18-2015 09:30 AM
Absolutely beautiful!!! I hope you make SEMA too, as i would love to see it in person....re the hood latches, on the 1/2 hole on the underside of the hood, you may need to clearance that a little more to compensate for the angle of the hood hinges (unless A- you are going lift off only or B- your angling the red male "receiving pin".
I had to on my 70, and now its getting redone in c/f as well...
Al Moreno 10-18-2015 09:31 AM
There is a lot more detail work then I have time to post right now. Hopefully we can get her done in time for SEMA.
waynieZ 10-18-2015 10:16 AM
I'm rooting for you guys! I hope it all comes together so you get it to SEMA. It deserves to be seen for everyone to enjoy.
Al Moreno 10-18-2015 10:29 AM
Thanks, we hope the clock doesn't run out on us.
As far as the hood pins, there so much though that went into just something that would seem so simple.
All of the install we've seen, the pin is just mounted on the rad support were the factory rubber bump stop goes. The challenge is it positions the latch to close to the edge of the hood line (See picture below).
http://i1231.photobucket.com/albums/...ps7gh69mj9.png
We eliminated the factory hood strut and came up with our own design. The picture below shows were the factory hood strut mounts too. GM designed the same circle on the drivers side of the hood.
http://i1231.photobucket.com/albums/...psootpg7ew.jpg
We used this location to position our hood pins to come through. This gives the illusion that the hood was design with these circles so that the pins would go through it.
http://i1231.photobucket.com/albums/...pshzihwwof.jpg
To accomplish this, Justin designed brackets in CAD positioning the pins to come out rough the original factory strut mounted location. (See back circle in picture below)
http://i1231.photobucket.com/albums/...psocrxzx8y.jpg
By doing it this way, the latch sit a couple of inches further back from the hood line making it more visually pleasing. The latch were also angled slightly to follow the cowl line instead of positioning them straight forward.
This is an example of the kind of attention to detail thats gone into this build!
Al Moreno 10-18-2015 10:30 AM
Thanks Wayne, I know you are!
Ron in SoCal 10-18-2015 05:15 PM
Pretty sick Al. The thought, detail and execution is mind boggling. Props to you and the boys :cheers:
Hoping you make SEMA and walk me through every bit of it :)
