-   -   The Most Detailed LS3 In The Universe! (https://www.lateral-g.net/forums/showthread.php?t=38904)
Jay Hilliard 10-19-2015 06:44 AM
Awesome Al. Great work! You and your boys are setting a new standard. Any aftermarket pieces potentially coming from the build?
GrabberGT 10-19-2015 11:50 AM
Great idea for the aerocatch bezel. I have a set to install on my carbon hood but have hesitated because I didnt want to cut out that large of a portion of the hood structure. I may just look into bonding the nuts into the bezel since a machined bezel is not available.
Al Moreno 03-08-2016 05:51 PM
Thanks guys for the props, its been a while since we've updated the thread.
Here a few random pics of the details stuff.....
Custom made bracket for the Racepac data logger. All the bolts are ARP 12 point stainless that have been milled, blasted and nickel plated
http://i1231.photobucket.com/albums/...psw4jvnvai.jpg
The Smart Wire eliminates all the fuse boxes and relays. It also uses half the wires you's normally would need in a harness. We calculated a weight savings of about 20 lbs .
http://i1231.photobucket.com/albums/...ps7b3jmz0j.jpg
The floor mats were just placed for the pictures. Once installed, they will bold to the floor.
http://i1231.photobucket.com/albums/...pseehpoeeq.jpg
The divider panel is just mocked up. The "R" is missing the center piece. It will be installed once the panels is bolted on.
http://i1231.photobucket.com/albums/...pschftokkk.jpg
The extinguisher was painted a lighter shade of gray. The brackets were blasted and nickle plated.
http://i1231.photobucket.com/albums/...psmlbclhbj.jpg
All the hard lines were polished
http://i1231.photobucket.com/albums/...psqiptv3hg.jpg
http://i1231.photobucket.com/albums/...psnyzb2wwd.jpg
http://i1231.photobucket.com/albums/...psnulgx0qs.jpg
http://i1231.photobucket.com/albums/...psvataoxzt.jpg
The pass through grommet for the fuel line. We also put a grommet on the other side.
http://i1231.photobucket.com/albums/...psulbjgjll.jpg
All the brake line brackets were ethier powder costed or nickel plated.
http://i1231.photobucket.com/albums/...pso3fbmhpx.jpg
http://i1231.photobucket.com/albums/...pse5lqyuie.jpg
http://i1231.photobucket.com/albums/...psbmqwucqt.jpg
Al Moreno 03-08-2016 05:53 PM
http://i1231.photobucket.com/albums/...pscodexbs0.jpg
http://i1231.photobucket.com/albums/...psv1j0aif2.jpg
http://i1231.photobucket.com/albums/...psyciae2ka.jpg
http://i1231.photobucket.com/albums/...psokbkggop.jpg
http://i1231.photobucket.com/albums/...psjvmtlydr.jpg
http://i1231.photobucket.com/albums/...psrf0y6do9.jpg
We replicated the factory tail light plastic covers in carbon and the plastic plugs with Ring Brothers bolts and washers. Only after blasting them and nickle plating them, LOL.
http://i1231.photobucket.com/albums/...pstjhlsvo9.jpg
http://i1231.photobucket.com/albums/...psu7dbiquo.jpg
http://i1231.photobucket.com/albums/...psrasrcxmv.jpg
http://i1231.photobucket.com/albums/...ps9itrye7h.jpg
http://i1231.photobucket.com/albums/...psmqropgqz.jpg
http://i1231.photobucket.com/albums/...ps5u3fxfs1.jpg
http://i1231.photobucket.com/albums/...psziltzto5.jpg
http://i1231.photobucket.com/albums/...pszqutytpp.jpg
http://i1231.photobucket.com/albums/...psy60qwcme.jpg
We prep the roof to run a black candy stripe down the middle.
http://i1231.photobucket.com/albums/...psswxkbptq.jpg
This is after removing the tape.
http://i1231.photobucket.com/albums/...psxo1yz8vk.jpg
http://i1231.photobucket.com/albums/...ps8btjfddw.jpg
Next came three coats of clear fallowed by sanding and another three more coats. Final finish pictures to come.
http://i1231.photobucket.com/albums/...psebpcbgqw.jpg
http://i1231.photobucket.com/albums/...psrffv2cse.jpg
Al Moreno 03-08-2016 06:46 PM
http://i1231.photobucket.com/albums/...psvdadqjqh.jpg
This connector was just used as a mock up to make the hole. The hole was drill exactly on the opposite side of were the steering shaft comes out of the fire wall.
http://i1231.photobucket.com/albums/...ps50g4z4xh.jpg
http://i1231.photobucket.com/albums/...pslezulel7.jpg
http://i1231.photobucket.com/albums/...psuzjyfla2.jpg
http://i1231.photobucket.com/albums/...pstpaeby2w.jpg
All the clamps were blasted and nickle plated
http://i1231.photobucket.com/albums/...psuiuq8bog.jpg
minendrews68 03-08-2016 06:55 PM
I think attention to detail is quite the understatement!!!!
Al Moreno 03-08-2016 06:56 PM
http://i1231.photobucket.com/albums/...psqvavwixz.jpg
http://i1231.photobucket.com/albums/...pshui8wuys.jpg
http://i1231.photobucket.com/albums/...psam5jkqkd.jpg
We made a sub splitter out of aluminum to compliment the factory rear spoiler wicker bill. We also had them powder coated in the same color as the Forgeline wheels.
http://i1231.photobucket.com/albums/...ps17guvfci.jpg
http://i1231.photobucket.com/albums/...psncmztdws.jpg
Even the Cobra seats got some love.
http://i1231.photobucket.com/albums/...psofdjtwfe.jpg
waynieZ 03-08-2016 07:21 PM
It looks amazing Al ! The Carbon part look great.
Jr 03-08-2016 11:21 PM
Al,
Beautiful craftsmanship.
