-   -   Norwood (https://www.lateral-g.net/forums/showthread.php?t=36443)
Sieg 12-30-2013 06:11 PM
Originally Posted by Sieg (Post 525638)
The frame is 46 x 26 and my welding table 22 x 36........let's just say it's a slight PITA.
I see a 30 x 48 x 3/8 table in my future. :sieg:
http://photos.smugmug.com/photos/i-K...-KwTW8Pc-L.jpg
http://photos.smugmug.com/photos/i-B...-BkF7khn-L.jpg
On a side note if a veteran TIG welder out there needs a tungsten prep assistant I passed my apprenticeship today. :bur2:
GregWeld 12-30-2013 06:47 PM
Okay -- I don't mean to bust your you know what here on a public forum ---- but dude! Get rid of that big ass TIG torch and heavy unyielding hose.... and get a torch that isn't fighting you all day!
This is just ONE style --- but trust me when I tell ya - the right size torch -- and a nice flexible gas cooled hose will make you a serious welder!!
Sieg 12-30-2013 08:16 PM
The hose is a flexi-flyer........:mock:
http://photos.smugmug.com/photos/i-f...f6d7fLp-XL.jpg
17 Series air-cooled TIG Torch. Fits any TIG welder that takes the 17 Series torch including the HTP Invertig 201, Invertig 221, Invertig 160DC.
Nothing makes TIG welding easier than a high quality TIG torch with a nice flexible cable – that’s why HTP offers replacement TIG welding torches for just about all brands of TIG welders – so you can get better results easier. All HTP air-cooled TIG torches feature one piece cable designs, constructed from an extremely flexible, silicon rubber hose with a braided nylon weave overlay. These cables even stay flexible in cold weather. This design puts much less strain on your wrist, and makes the torch feel lighter.
Torch isn't huge and works well for my big hands, but I wouldn't mind a swivel head.
http://www.usaweld.com/v/vspfiles/photos/SH-9-12-1.jpg
GregWeld 12-30-2013 08:35 PM
AH!! GOOD! It looked like a garden hose in the pics! A flexible hose is really critical IMHO.... almost as important as being able to see!
My TIG torches have flex heads -- not swivel heads -- but you can bend the neck.
I personally like to use as small of a torch as possible --- both MIG and TIG.
GregWeld 12-30-2013 08:42 PM
Here's a good reference....
http://www.ckworldwide.com/standard.htm
Sieg 12-30-2013 09:11 PM
CK-17 is the torch that came with the HTP Invertig.
GregWeld 12-31-2013 06:45 AM
Yeah - that's standard --- You'd LOVE a CK9 (two series) with the flex head!
Just do it!
Sieg 04-22-2014 11:07 PM
Retractable seat belt installation to be continued....due to server issues.
Sieg 04-22-2014 11:08 PM
Headlight & grille screen installation........to be continued
Exhaust mods to be continued...........
Sieg 04-22-2014 11:09 PM
Power steering cooler installation.........to be continued
Sieg 04-22-2014 11:32 PM
I finally got around to tearing into the rear end to upgrade my axle's 7/16" wheel studs to match the 1/2" ARP front studs. Embarrassingly for as long as I've been a Lat-G member I thought I had installed C-clip eliminators years ago and thus had postponed installing rear disc brakes! Guess that's what happens when you have a car 24+ years and get into your mid 50's..........:sieg:
Anyway after contacting Moser and verifying I could simply tap the existing 7/16" press in stud holes since they are drilled the same size that's required for a 1/2-20 tap I tore into it today so when the ARP studs arrive in a day or two I'll be ready to button it back up.
First thing was to insure the tap would be square so I made a quick jig from scrap laying around.
http://photos.smugmug.com/photos/i-f...fHPTBbc-XL.jpg
The other concern was being able to get the rear cover off and be able to properly seal it during the reinstall due to clearance with the Flowmaster transverse muffler. Tight but doable.
http://photos.smugmug.com/photos/i-d...d5x5XvG-XL.jpg
The other motivation is I wasn't positive of the rear end ratio as the last time the cover was off was in '92.........I think. 14/44/3.38 confirmed.
http://photos.smugmug.com/photos/i-J...Jnc2QZx-XL.jpg
Side shots with freshly threaded axles waiting for studs.
http://photos.smugmug.com/photos/i-w...w7Kjwzs-XL.jpg
http://photos.smugmug.com/photos/i-J...J7Ww8q4-XL.jpg
rickpaw 04-23-2014 04:08 AM
Keep us posted on your wheel stud install Sieg. I'm about to upgrade front brakes with 1/2 ARP studs, and have the same 7/16" studs out back.
Sieg 04-23-2014 07:46 AM
Tu - With my Moser axles it was simple. The press in studs popped out easily, tapping was tedious but good exercise, all that's left is to screw in the studs and reinstall the axles. I'd assume stock axles would be similar other than slightly stubborn studs due to rust.
rickpaw 04-23-2014 10:11 AM
I had a shop pressed in new 7/16" stud when I converted the rearend to disc brake, so it should not be too hard to tap them out. I'm a bit more worry about tapping the holes, as my hands are not as steady as they used to be.
Tu
Sieg 04-23-2014 12:23 PM
Tu
If you can't make a tap guide like I did get one something like this: http://www.amazon.com/Hand-Tap-Guide.../dp/B000ZN30U4
I also used a longer T-bar in the tap holder which helped a lot.
intocarss 04-23-2014 03:41 PM
Nice job. I've never heard of or didn't think they had a "3.38" GM 12 bolt gear ratio, Is It an after market gear??
Sieg 04-23-2014 04:23 PM
Well my tooth count was 44 x 13 Ring divided pinion equaled 3.38. However those are big numbers for me to count :sieg: Could be 43/13 3:30's, either way they're not 3:55's or 3:73's which I'd consider optimum. 3:73 concern me due to noise.......seems that ratio just isn't quite.
intocarss 04-23-2014 04:43 PM
How about 3.42 41x12 ;)
Sieg 04-23-2014 08:18 PM
Sieg's Stud Service........
http://photos.smugmug.com/photos/i-m...mCkVZB4-XL.jpg
Has a nice ring to it. :D
GregWeld 04-23-2014 08:55 PM
I called -- Amy is not real keen on the new business name.
Don't forget the locktite.
Looks good!
Sieg 04-23-2014 09:10 PM
One drop of Red and seated with 3/8" butterfly impact which hits 60-70 ft. lbs. Wheels are torqued at 75 lbs. We shall see.
Sieg 04-23-2014 10:31 PM
Axle code is BS 0107G1
Manufactured on Jan 7th, by Detroit Gear & Axle, shift 1.
BS = 3:31 ratio, so I missed the ring gear by 1, 43/13= 3.3076. :thumbsup:
intocarss 04-24-2014 12:04 AM
And I had totaly forgot about the 3.31 gear :bang:
Vince@Meanstreets 04-24-2014 12:15 AM
in the city..a big hit
Vince@Meanstreets 04-24-2014 12:16 AM
of course you did, you silly straight liner
intocarss 04-24-2014 08:02 AM
I KNOW HUH!
Ron Sutton 04-24-2014 05:38 PM
I dunno Greg ... I sorta like the new biz name. :lol:
GregWeld 04-24-2014 05:44 PM
Good business plan - but he may come up a bit "short".....
Sieg 04-24-2014 05:50 PM
You're certainly qualified to make that statement. :captain1:
Sieg 04-24-2014 08:56 PM
Ready to roll!
http://photos.smugmug.com/photos/i-7...7Wdrvzg-XL.jpg
http://photos.smugmug.com/photos/i-5...5wFJh2Q-XL.jpg
My USCA non-compliant unsafe tires :(
Flash68 04-24-2014 11:09 PM
Looks great Scotty.
So what is the date on those tires?
Sieg 04-25-2014 12:07 AM
Originally Posted by Flash68 (Post 547530)
Looks great Scotty.
They're about 3.5 years old. Understand the intent of the rule, but regarding safety with a 46 year old car tires are the last of my worries. My rear drums qualify and I'm more concerned about losing brakes on the road course than having a tire issue.
Tough justify $500 for the entry and $1300 for tires just to run an OK track. I'd spend it on track days and expenses at Oregon Raceway Park, The Ridge, or T-hill first.
I don't agree with being able to circumvent the 'safety' regulation by using a lower quality date code conforming tire.
96z28ss 04-25-2014 12:11 AM
$1300 for tires? what tires you looking at?
Sieg 04-25-2014 07:19 AM
That's for new NT05's
rickpaw 04-25-2014 07:28 AM
Local Discount Tire (America's Tire in west coast) quoted me a hair above $800 for 4 NT05's (245/40/18 & 275/35/18) mounted/balanced. Just have to bring my new wheels down to them.
Ron in SoCal 04-25-2014 07:35 AM
I think I paid $1150 for a set of the big'uns on the web.
GregWeld 04-25-2014 07:53 AM
When you drive the Lotus on the Hoosiers - and finally feel brakes that stop better than you wanted them to -- and realize a 1.8 liter Toyota motor will smoke your SBC by margins of MULTIPLE SECONDS -- on a real track -- you won't want to bother trying to make your street car into a race car. LOL
fleet 04-25-2014 08:08 AM
Then why all we all here?
:confused59:
lol
Sieg 04-25-2014 08:36 AM
Couldn't get an online quote from their website.
I used Summit for pricing. When I do replace I'll most likely end up with a run flat style but that's most likely a couple years away.
Oh I know! I have a bike in the garage that my Camaro can't even sniff, especially in the adrenaline category. The USCA deal is about being around the people and watching the 'players' cars run for me. :D
That being said.........once you drive my Camaro you'll sell the Mustang.
:rofl: :rofl: :rofl: :rofl:
