hey Marty
The rear UCA ?...no its the same length....maybe a turn or two different. I tried to run it in the middle of its threads to give me as much adjustment longer/shorter as possible. Other than that, its the same length as it comes form Ride Tech |
Looks good, Ned!
Does look good Ned, nice progress and thanks for the update.
Nice to see your still at it progress is golden keep chipping away a little at a time just keep your eye on the prize. you are going to run into alot of hurdles when you take on a build of this nature and you are doing a great job overcoming them. great job on the build keep up the great work!
if you want the tip to always stay in the same location, you want to hard mount the tip centered in the valance and have the expansion joint before it, so that the tip will always stay in place as the exhaust moves around. |
Yes,more mopars.:thankyou:
Yeah Bob I know the expansion part of the joint really isn't going to come into play with the current mount......it just gives a little more ability to adjust the tip and then clamp it down.... Not that worried about expansion that far back anyway... I have a bigger one mounted further up stream....
nice work ned. All this time i thought it was still at Chris's place.
Looks good man :)
| All times are GMT -7. The time now is 04:28 AM. |
