-   -   Norwood (https://www.lateral-g.net/forums/showthread.php?t=36443)
GregWeld 05-23-2014 10:23 PM
BINGO!!!
Originally Posted by Sieg (Post 552275)
Thanks to Blake's mention of Mark Williams........
Critical speed is the speed at which a spinning shaft will become unstable. This is one of the single largest factors in driveshaft selection. When the whirling frequency and the natural frequency coincide, any vibrations will be multiplied. So much that the shaft may self destruct. Another way to think of this is that if a shaft naturally vibrates at 130 times a second, and one point on the shaft passes through 0 degrees 130 times a second (7800 RPM) then the shaft has hit a critical speed. There are several ways to raise the critical speed of a driveshaft. You can make it lighter, stiffer, or increase diameter without increasing weight. This is the reason carbon fiber makes a good driveshaft, it is stiff and light and can be made to any diameter or wall thickness. Aluminum, while it has a very good critical speed is not quite as strong as steel. Steel, with good strength characteristics will have a lower critical speed.
http://www.markwilliams.com/Images/critspeed.jpg
Vince@Meanstreets 05-24-2014 06:08 PM
Originally Posted by Track Junky (Post 552256)
Sheeeeet........Wish you were close enough to make the drive. Hate to say it but if its not the trans it has to be the amount yoke sticking out of the trans. My follow up fix would be the correct length drive shaft. My brother-n-law just bought a truck load of stuff from Amir Rosenbaum(old owner of Spectre) and one of the items was an aluminum drive shaft. I could talk him into given it to you for cheap if your interested.
Originally Posted by Sieg (Post 552260)
Size matters!
Norwood is 45.25" from end of output shaft to bolt face of the rear yoke. :D
no bueno, it was the spare from the 2nd gen....too chort.
Sieg 05-24-2014 07:25 PM
Size matters!
Appreciate the offer and confirmation. Probably best I keep it local anyway since there's a decent shop here. :thumbsup:
glassman 05-30-2014 09:11 PM
So whats the final tally? did it work? or should i say does it work?
Sieg 05-30-2014 09:36 PM
The final result is it's as close as it's gonna get. At the current ride height the trans/driveshaft is 2.2*/1.6* - 0.6 and the pinion is 5.0*/1.6* - 3.4. That combination produces the least vibes. It's fine at cruise speeds and low triple digit range. It's just noticeable coming off cruise throttle.
To get it right will require getting the pinion lower to get more working angle at the trans/driveshaft u-joint. The 1" blocks lift the pinion too high so they need to be eliminated by using reverse eye leafs or a 4-link. At least that what I've concluded. As is the engine/trans angle is high by .3*-.8*.
After 15 pinion angle changes and test drives..........have I mentioned that I hate leaf springs lately? :D
Sieg 06-04-2014 05:30 PM
In an effort to neutralize the little vibe that's left I'm going to replace the right side Moroso solid motor mount with an Energy Suspension urethane mount and see if that has any neutralizing effect. I'm leaving the left side mount as the header to steering box clearance is about 3/16".
Thoughts?
glassman 06-04-2014 05:47 PM
While you loose torque (a little) on one hand, i believe the polyurethane to dissipate harmonic (wave) energy.....I mean if you placed your whole driveline on a sponge, you'd probably have no vibrations....
Roberts68 06-04-2014 06:08 PM
Glass man, is that proven or just a seat of the pants "torque sensing" observation?
That sounds snide but It is a sincere question because I do not know. And you have sparked my curiosity.
Does Poly or a rubber mount actually lose, or absorb torque?
I would think not, that it would only dampen the inrush of torque being applied to the structure. All the torque, or rotational forces at work are going to get to their fullest extent of allowable movent in due time are they not?
Track Junky 06-04-2014 06:34 PM
I personally do not like or use solid mounts. I do believe that the poly's absorb harmonics which is why I prefer them.
Sieg 06-04-2014 07:37 PM
The most annoying vibration feedback I'm getting now is in my right foot which tells me motor mounts.
The concern is the steering box clearance.
Are the urethane mounts rigid enough to keep the header from contacting the steering box?
http://photos.smugmug.com/photos/i-p...p23Dmm2-XL.jpg
..........oops! Just realized I forgot the F'n idler arm! :sieg:
http://photos.smugmug.com/photos/i-s...sDgdTCG-XL.jpg
GregWeld 06-04-2014 07:39 PM
Just burn it.
:D
Track Junky 06-04-2014 07:41 PM
Toss the headers and get some that fit right. Who makes those?
Sieg 06-04-2014 07:48 PM
Originally Posted by GregWeld (Post 554466)
Just burn it.
:D
Tried it..........epic fail............again.
Sieg 06-04-2014 07:49 PM
Doug's D368's..........they fit right.
http://photos.smugmug.com/photos/i-9...9s6ZtPV-XL.jpg
Flash68 06-04-2014 08:46 PM
Thoughts?
Solid mounts in your reverse burnout street car? Interesting..... :popcorn2:
Vince@Meanstreets 06-04-2014 09:35 PM
any witness marks?
Take another look, is there any part of the engine/trans touching the body? Trans bellhousing bolts? The ones on the drivers side.
Solid mounts transmit alot of NVH.
Sieg 06-04-2014 10:03 PM
http://www.acurazine.com/forums/imag...ies/finger.gif
:cheers:
Sieg 06-04-2014 10:28 PM
Originally Posted by Vince@MSperfab (Post 554494)
any witness marks?
Solid mounts transmit a lot of NVH.
Just to clarify regarding witness marks......the motor is still solid mounted.
The vibe in the throttle is most noticeable when cruising at highway speeds of 60-75 mph while using light on/off throttle inputs to maintain speed or following distance.
To the best of my knowledge there are no contact points as I clearanced/smoothed the firewall when I installed the transmission and I've had it out once after the initial install and there's good clearance around the bellhousing bolts.
No witness marks on the steering box or idler arm.
I've 'heard' the urethane mounts are pretty rigid but those clearances are pretty tight, thus why I'm leaning to replacing the right side only and see if anything changes.
Vince@Meanstreets 06-04-2014 11:28 PM
even if you change one it won't make much difference since the other side is solid mounted. It would if you had a hinge or spring mount that will flex.
One of the ways to find the frequency of the vibration and with some mathematical calculations you can determine if its engine, pulley or rotational issue. A simple tool for measuring the vibration frequency is the sirometer you can get one from Briggs & Stratton shops.
We use to use them to determine and narrow down causes of vibrations in Dodge diesel trucks.
SSLance 06-05-2014 04:26 AM
I have newish poly mounts on both sides in my car and I have witness marks where my header contacts my steering shaft...which has over a half inch clearance when sitting static.
Being all too familiar with solid mounts to cure clearance issues on other cars, I'm tempted to say you might need to learn to live with the vibration if they are the cause. You've gots some tight spaces there...
GregWeld 06-05-2014 07:38 AM
Funny how we try to turn a 45 year old Chevrolet into a Rolls Royce....
Sieg 06-05-2014 07:41 AM
What?............I couldn't hear a word you said over the exhaust.
SSLance 06-05-2014 07:44 AM
We do it because we can...
Payton King 06-05-2014 10:08 AM
Looking at the front of the motor it will rotate counter clockwise under load. If you have room for it to move up slightly you would not have issues. Not sure how much it would move under a motor braking situation in the opposite direction.
Remember back in the day putting a chain on the driver's side of drag cars and keeping the rubber motor mounts?
Sieg 06-05-2014 11:10 AM
Payton - I haven't ruled a limiting strap out. :thumbsup:
Vince@Meanstreets 06-05-2014 11:16 AM
The polys have an internal lock for over travel. The amount of torque time is very little, you can compensate with an intake tornado plate. OR just put your foot in it farther.
intocarss 06-05-2014 11:45 AM
If you don't want any vibrations....... buy a Lexus :G-Dub:
Sieg 06-05-2014 12:09 PM
Aren't those made by Prius?
:bitchslap:
Vegas69 06-05-2014 04:39 PM
And end up with the refinement of an 84 Citation.
intocarss 06-05-2014 11:01 PM
:bitchslap:
Saw a black Prius with old school red and orange flames the other night.:disgusted:
Sieg 08-30-2014 09:21 AM
Had a little time to do some investigative videoing. Why? Simply because I've never seen what's happening in these areas of the car.........in 25 years.
Nothing real exciting, with the exception of the brake check @ 3:34 in the front suspension video.......at least it was for my daughter. :unibrow:
Spiffav8 08-30-2014 11:40 AM
Cool to see all that in action and it's nice to know that you've put it together properly.
Sieg 08-30-2014 12:16 PM
Primary reason was to check the range of suspension travel. Front was as expected, rear was much more than it feels like.
Also appears that reverse eye leaf springs or a 4-link would resolve my pinion angle related vibration. Those lowering blocks reduce the u-joint working angles and create too much leverage on the springs thus adding to pinion deflection.
Vegas69 08-30-2014 01:01 PM
You should really tear that front suspension apart and detail it. On second thought, why be a conformist with a car that doesn't move. ha ha ha
Sieg 08-30-2014 03:19 PM
Doesn't move? I'm driving it 5-6 times a week on average. There's also a spare subframe sitting in the garage. You really need to have a couple kids to better understand. :twak:
.........until the rains come. It's not that the car is that nice, I just don't need a reckless driving ticket. :sieg:
Vegas69 08-30-2014 03:58 PM
I was talking about the list of bozos in the jack stand class...
Sieg 08-30-2014 04:02 PM
I figured so..........You still need a couple kids. :unibrow:
GregWeld 08-30-2014 08:28 PM
Too bad it's another poopie Camaro or I'd have a whole basket full of cast off parts... Guess I'll have to give 'em to Basher instead.
Sieg 08-30-2014 08:47 PM
Proof that 60 Sucks!
Vince@Meanstreets 08-30-2014 09:18 PM
haaaa haaaaa
