Installing the pistons
http://www.nelsonracingengines.com/l...0-ls-build.jpg if you havent used one of these tapered ring compressors yet get one they are slick as hell and make installing the piston a piece of cake.
Installing pistons
Pistons installed
Orings installed
http://www.nelsonracingengines.com/l...6-ls-build.jpg
This is a close up of the tempered stainless wire we put in the oring groove we cut in the block.It works fantastic and does not lose its postiveness once you torque it once it allways stays out and proud.Harder to install but well worth it |
More to come tommorow
I'll post a bunch more tommorow talk to you all soon
Looks very good Tom ! Good builders go the extra mile, you are going 3 or 4 miles...:thumbsup:
Jason |
Very Cool...Wayy more interesting than looking at my diesel engine stuff here at work :thumbsup:
You build some awesome engines. I have a gen 1 sbc its a World 454 with a 4.250 in bore Will the oring work on my engine to put a small amount of boost to it or is it too tight with the bores that big?
Thanks Wayne |
4.250
| All times are GMT -7. The time now is 09:42 AM. |
