BESIDES YOU'LL NEVER EVER HIT YOUR HEAD!! |
I've got two of these -- with the pedal.... used 'em today as a matter of fact. I ALWAYS stabilize the front of the car if I'm working on the rear end - or vice versa... And sometimes I use my air driven hydraulic tranny jack to raise or lower the rear end - while checking the panhard bar - or something else... and I want the front "stable" while jacking this stuff around.
The car I'm putting together for my buddy -- had a metallic noise coming from the passenger rear... and since I didn't do the brake work (Wilwoods) -- I had to investigate the source. To remove the big ol fat wheel and tire - you have to undo both coilovers - and the sway bar and get the rear end down as far as possible to clear the rotor as there's not enough distance between the fender lip and the rotor to clear the tire! Turns out that one pad was installed with the metal backing to the rotor rather than the pad!! I had to take a picture of that! LOL Again - the thread asked about STORAGE lifts -- but I can tell you that what I was doing today - would have been a HUGE hassle on a 4 post (posts are for beds)... and worse had I not had this stands to raise and lower the rear end etc. :cheers: |
I much prefer a 4 post. 1. Faster to lift as you drive on and go, no setting the arms 2. Much more stable (I've personally had cars slide/move on the arms of a 2 post, more than once....................) 3. I would go as far as to say that most home slabs are not thick enough to properly support a 2 post lift (6" minimum slab thickness recommended in most cases) 4. Portability............ I can move my 4 post anywhere in the shop or outside for pressure washing the bottom of the car Jody |
Oh sure Jody -- One of ya lies and the other one swears to it!
:rofl: |
If we didn't stand eye-to-eye I might take that the wrong way! :lol: |
Thanks for all the input, guys. :thumbsup: The guy who I asked the question on behalf of has a heated slab, so a 2 post is absolutely out of the question.
Maybe I'm just too used to industrial strength drive on racks, the platforms are far bulkier than the home ones. |
I take full responsibility for the demise of this thread. :lol: Maybe the reason I'm so pro 2 post is because I never cared that much if I dropped someone elses car. :D
Now I'm only jealous that this guy has a heated slab...
Todd -- you don't have any need for a heated slab - yours is probably cooled... :rofl: |
| All times are GMT -7. The time now is 11:02 AM. |
