-   -   Its Time For The Builders To Come Together And Stop This Crap (https://www.lateral-g.net/forums/showthread.php?t=26381)
ccracin 04-16-2010 07:12 AM
Originally Posted by Stuart Adams (Post 282401)
These type of events are in every aspect of life. Not just car resto's. Every type of business from doctors to plummers fix other stuff all the time. It's never going to change. Research your purchases and get qualified help to help you. Even then there is never a guarantee. Buyer beware.
Very well put Stuart!
rwhite692 04-16-2010 09:07 AM
Exactly...in our business (semiconductor design and mfg) we were recently burned by a piece of design content that came along with another company that we bought...the problem was contained within a library of design files for the chip which was done by others (was subcontracted, probably to the lowest bidder)...The design was not well executed and full of bugs which cost our company a huge amount of time and money to fix, pissed off customers, etc.
There will always be people out there who are going to cut corners in order to take the business away from the other more capable companies based on price.
Caveat Emptor, indeed.
BRIAN 04-16-2010 09:31 AM
Everybody has an idea of what quality is. It is hard to critique a build unless you know exactly went down between owner and shop in regards to the build and money spent. Yeah, everybody is going to scream quality shouldn't be dependent on money but it is or at least it should be. Quality takes time and hours which translates into money.
In regards to bondo use, when you are applying it you always need more to get the car level and when you are stripping a car you always say they used too much. With the cost of repairs the amount used should go down. There was a famous $1mil plus car damaged that had a 1" think bondo chunk missing. I would say the quality there is questionable but if I found the same on a quick $1500 job?? what are you going to say as not everybody has deep pockets or the desire to have that quality.
The internet is full of so called Pro's showing their work on sites that is just beyond backyard bad and there are 20 -100 replies saying how great the work looks just because the shop is the site favorite. It is on here and everywhere else. One has to sit back and see who is making the comments and determine if they are on the same page as you in regards to quality. Do they actually have finished cars? Do you see their cars at shows doing well? Problem is guys take this info and think it is the correct way to do repairs.
There are plenty of very quite small shops delivering serious quality. Don't shop for cars or shops on the Internet. Go to shows or cruise nights and spot some cars that you feel are quality and ask where they were done. You will wind up with what YOU want.
Vegas69 04-16-2010 09:42 AM
Brian, you have some good points. To often people are quick to give positive feedback based on a photo. We all know you can make a turd look good in the right lighting. You also have your know it alls that don't even have a car or experience with that part or process. I like to pick and choose the people I trust and rely on them for advice. I've got to the point now where I call people out if I feel it's the wrong advice. These forums are really encyclopedias for future car nuts to find on google. We're all guilty of putting out some bad advice here and there but we need to try and keep our flappers shut if it's hear say.
bentfab 04-16-2010 09:50 AM
Originally Posted by 1984 camaro (Post 282310)
I had a so called builder for chatsworth ca. that done a mini tub and a custom engine bay. The engine bay was on the cover of hot rod, Yes it looked good but there was about 5 gallons of mud to shape the engine bay which at sema show was starting to crack, The list goes on The rear axle and rear rails were a total sh*t job the shocks were angled up over the axle and when the car traveled down the shocks would bind on the housing in fact just from trailering the camaro the shock adjusters were worn away, The top and bottom bolts were mount 90 degrees from each other and when the traveled the shock rods would bend, He also messed up the axle seals. Now the engine bay some of the welds were so weak I pulled out one panel by hand. He clearanced for the wipers but they hit and would not work. The firewall had holes into the interior so his fix was to fill them with foam spray but that still had some leaks, In fact I washed the car and more water was in the car than on the floor. the best part was the hood would not close since he made a custom radiator cover and it was a little to high and hit the hood. This list goes on and on.
This was a $50,000 bill for this work so big money does not always get a good job. I needed to post this so you fellow car guys stay far far awayfrom this builder.
I have the car back and cut the floors out and the engine bay. It is sucky feeling walking by the scrap bin and looking at my $50,000 and knowing its about $30.00 of scrap iron.
Randy
Well Well Randy,
Nice of you to open your mouth with out even calling me? In my opinion I would call the shop or customer first before going public.
1st: Why don't you man up and instead of calling it a shop in Chatsworth call it Bent Custom and Performance.
2nd: This car was a headache from day one. I was sub-contracted and was always put in a rush !!! (There was never a clear picture from day one and I always asked what are the plans for this car? ) Considering the backhalf was done a year before the front half and that wasn't on my watch.
3rd: Do not point fingers either ( I have never touched spray foam in my life) That was the paint shop who ground down the metal to much because they don't know how or what the fu$@ they are doing!!! I wasn't the one who did any final assembly and God knows the monkeys that put it together had any clue what they were doing."there was about 5 gallons of mud to shape the engine bay" If I'm not mistaken before the cars engine bay was started I think there was the same amount of bondo in it when YOU did the job. So don't go calling the kettle black.
4th: "when car traveled down the shocks would bind on the housing in fact just from trailering the camaro the shock adjusters were worn away, The top and bottom bolts were mount 90 degrees from each other and when the traveled the shock rods would bend, He also messed up the axle seals." There you go again. As for the shock adjusters The paint shop fu## those up because they never assembled the car properly or asked for any help !! Plus they wanted the car to sit lower than the way it was designed. Mater of fact since they screwed those up I even bought new shock nuts (Funny there still sitting in my shop).
5th: "He clearance for the wipers but they hit and would not work." There were a few conversations about this? If we can make them work great if not then at least get them on and we will finish it up after SEMA. And if any of you guys on hear know windshield wiper systems aren't easy to figure out when there custom. Especially when the contractor tells you to put the Hydroboost and master at a 90 degree under the dash (Which in my opinion was stupid,but I was just doing my job). Also put all the electronics,new Vintage air, all the coil packs, and a manually operated throttle cable. O' don't let me forget to remind everyone. This was a 4 week job that should have been a 6 to 12 month job.
6th: "The firewall had holes into the interior so his fix was to fill them with foam spray but that still had some leaks" Are you refurring to "his fix" as me ? Because his is not me. I don't have that kind of mentality. Sorry but there you go pointing fingers in the wrong direction again.
7th: "the best part was the hood would not close since he made a custom radiator cover and it was a little to high and hit the hood." Well if you look at the origanal metal pic in Hot Rod and the final paint pic they are different. May...be.. the painter cut and fudged it then slapped on a ton of bondo painted it and called it a day. Pointing fingers again
8th: I could stand here and defend my self all day. But what good is that going to do? I'm just stating the facts. I have pics to prove it all day.
9th: It's a shame that Randy had to post this up when he dam well knows how all this came about. [COLOR="red"][COLOR="Black"][B]Some one else was calling the shots not me !!! The given amount of time that I had to do all this would make most of you go insane or tell the person to go some where else. There were alot of unfinished aspects of this car that never got finalized or were covered up by people that are'nt professinal or understand what the were doing.
There are a few of you guys on here that know me and have met me in person. I even have done work for you or are currently doing work for you. I think I can vogue for all of you that I'm not the person or builder that Randy is pointing fingers at or accusing me of wrong doing.
Mark
bentfab 04-16-2010 10:04 AM
Originally Posted by DB Z28 (Post 282326)
I guess you got Bent over on that one
Not cool.
Originally Posted by DJW32 (Post 282370)
:wow:
That's what I said
Originally Posted by skatinjay27 (Post 282371)
So tell me? Do those peaces and wheal tubs look like crap? Not to many people take pics of raw metal and post.
Originally Posted by elitecustombody (Post 282395)
I think Chris emphasized in post # 6, that small shops can't put out high quality work ,at least that's what I got
Everyone starts out small. Some stay that way others have talented workers.
Perfect !!
Too true !!
That's the first car I thought of.
My doors are always open.
ironworks 04-16-2010 10:13 AM
Some good ideas in this post, I just wanted to add to what you saying.
Just because it is at the show and looking good does not mean it does not have a 10 gallons of mud. I think you need to see a guys metal work. You need to go TO THE SHOP, Don't talk to some one on the phone and see what they post. You can tell alot through this but it does not show the whole story. I love the shops that post pics of some crazy metal mod and it goes from being tacked up and barely cobbled together. To complete bodywork with primer and looks like it is prepped for paint. If I had a shop chop the top on my car and I went in and never saw the car in bare metal, I would know something is wrong. There are more shops out there that sculpt bondo then fill small highs and lows. Every car will use filler, just not something more then a 1/16th to maybe an 1/8th. MAYBE.....
Just cuz a guy finishes alot of cars does not make them talented. It just means he builds alot of junk. Some guys only do one aspect of the build. So guys just paint cars, Some guys just assemble cars, Most guys do light fab work and paint the car and reassemble. So shops are just general contractors and haul the car all over to have other shops do all the work, then they reassemble the car and take all the credit. That happens to us all the time. We are a fab shop, We can turn key a car, But 95% of our work is pushed in and pushed out to just to certain segments of a build, Chassis, and body fab.
The Last issue I see is this website, Lat-g in General. There are some very nice well put together cars on this site. People have paid alot of money to put some of these cars together. The MR Average Joe gets on here and sees things Way above average results and has no clue how much time or Talent it takes to build some of the things posted on this site. You cannot get a top notch paint job for 8 grand. You can not get a full custom tube chassis for 18k. You cannot have some one build you a crazy top notch, bad ass, Top Quality Camaro for less then 125. Sure you can put a car togther for less and it can be COOL. But Cool and Quality are totally Different. And to have both Cost even more money. These hand fabbed top notch quality cars cost a lot for a Reason.
I have gone an looked a few hack jobs that have been on this site that the customer wanted me to fix. I asked them how much they paid and told them I thought they got what they paid for. They were not happy, because the work did not look like what they see on here, but It also did not cost 1/2 of the price.
You get what you pay for. Unless you do not do your homework.
ironworks 04-16-2010 10:20 AM
Todd, I think you are a good example of a guy who learned his lesson on your engine and went to a guy for your 2nd engine that was not the lowest bidder I'm sure. And really at the end of the day, it is alot of the same parts, Meaning a big block is a Big block, yeah yeah I know, not quite, but bare with me. But the way this new one runs and the operates is miles different from the old one, let alone the assemble and parts selection and just overall knowledge.
I use the example of My moms cooking, You don't know your mom is a bad cook when your a little kid, until you eat somewhere else and have something to compare it to. Somethings you just take for granted until you find out you did not have all the info. OR you just never learn.
chr2002ca 04-16-2010 10:42 AM
Originally Posted by ironworks (Post 282465)
I use the example of My moms cooking, You don't know your mom is a bad cook when your a little kid...
Even when I was a little kid I knew my mom's cooking sucked! I didn't have to go elsewhere to figure that out. When you need a spoon to eat your eggs, something ain't right. :lol:
That Mustang breaking in half is just rottenous to the core. From my own experience and what I've seen, I don't think it matters how much you spend or how big or little the shop is. You just have to research that particular builder and see their work in person and talk with that builder's customers. That's about the best you can do. Or, try to do it yourself and live with your own work.
DRJDVM's '69 04-16-2010 10:45 AM
I think Stuart summed up the way I feel..... this kind of stuff happens in EVERY business out there....and it always will.......
Happens in my job all the time....... we see a pet, provide an estimate for whats needed...... the owner declines, and takes it somewhere else based solely on $$.....I've even had people get on the cell phone right in the room and start calling around for a better price :).... then they try and negotiate with me. Not going to happen... I've also had to "fix" other vets crappy work.... I've seen some real disasters. I've seen pet die after taking it somewhere cheaper...pets that I KNOW I could have saved......
Sometimes clients will pressure you with time or ask you to cut corners or keep the cost down dramatically. As a business owner, sometimes you have to just say NO..... the end result will be a reflection of your work no matter what. Others looking at the car wont know that the owner wanted you do do $10k of work with a $2k budget in record time. Sometimes you have to walk away and say "no thanks". I try to work some aspects of the cost, but I draw the line and say....."I wont do that....if thats what you want, you need to take the pet and the record and find another vet". The ones that I've cut corners on ALWAYS end up being the worst situations..... things dont go well and the owners gets pissed.....not my fault, but guess who get left holding the bag? The owners arent going to go and tell their friends that the reason the dog died was because they were so frickin cheap and would let me do what was really needed.... they are going to tell their friends that it died at our hospital under my care.......
I'm also the first to admit that I got suckered into going with a lower bid for some work on my Cuda. I contacted alot of shops and got prices all over the place. I found a guy that talked a good game and was working on another members car...his price was good (better than most of the guys I contacted), so I went with him.....HUGE MISTAKE....his work was terrible and I ended up paying 2x as much just to undo his work and start from scratch on several aspects of the car. I regret that decision more than you will ever know....especially since I did exactly what I rip some of my client for.... I focused more on the final $$ rather than the value of the $$. For that I beat myself up over and over.... I learned my lesson and wont make that mistake again. Thats not say I wont try to keep my budget under control, but I'm not going to let the $$ be the biggest factor again. He did **** work but ultimately I have no one to blame but myself.
But high $$ doesnt always mean high value.... thats where the consumer has to do their homework.
I would also like to comment on BentFab...... I just met Mark at his shop a couple of weeks ago and was more than impressed on the work he had going on in the shop. 2 of the 3 project he had were in bare metal and everything was pristine......very nice CRAFTSMENSHIP.... I was very impressed and would have no doubts about letting him work on my cars. I have no doubt that any shortcuts made on the project mentioned above, have alot more "backstory" than meets the eye... I highly doubt that they were ther result of Marks decisions.
The issue also comes into play when there is more than one shop doing the work. One shop may do fantastic metal work and then the paint shop does a crappy job...so the first shop gets dragged into the "that car is a POS"
