1 Attachment(s)
I made a little more progress this weekend. Made the caliper mounts and tacked them in.
1 Attachment(s)
Also got the LCA's set where I wanted them. 0 degrees.
1 Attachment(s)
And the torque tube started. Looks like Im going with a 60" torque tube to simplify packaging. This will allow me to mount the pivot end directly to back of transmission mount.
1 Attachment(s)
Ooops. Out of order. Here's another of the LCA with Johnny Joints from Spohn performance. I intentionally off set them. Oh....and that's actually not rust above them. Lol. Although I am changing the floor pan this summer. Lol.
1 Attachment(s)
Got the trunk pan cut out. I decided I couldn't get the upper Airwaves mounted where I wanted it without cutting it.
1 Attachment(s)
And the upper Airwave mount bar mocked up.
Coming along nicely!
Thank you. Slow and steady. I swear sometimes I meet myself coming in from the shop. Lol.
I should mention that I may keep the big block and add a T56 Magnum. And also add a 509 cu in stroker rotating assembly. But I'm still fretting over the stack injection. :G-Dub: I may go with an AMD Al front end to offset some of the weight. Its a constant battle with myself over what should be done. Lol. David |
1 Attachment(s)
Been a while. Here's a few updates. I'm experimenting with a side exit exhaust system. Just a mock up for now. Already wanting to change some things.
1 Attachment(s)
And another....
| All times are GMT -7. The time now is 06:18 AM. |
