Moving along............
You certainly are, and at a good clip too!! |
Great job as usual Ken, damned if these motors don't look like they are right at home in there....
T, |
Looking good Ken ... question, who's intake kit are you installing?
Thanks, Michael |
Pieced together parts from Ebay............ |
O.k.........Update......Got the fuel line completed......new spark plug wires to clear the headers.....upper and lower Radiator hoses pieced together and installed.....and the air inlet system is completed and installed.......Steam line and heater hoses will be completed today........PCV system and Power Steering hose are about all that's left to do in the engine compartment other than wiring.....Here are some pic's
http://i13.photobucket.com/albums/a2...2F7D2A7F16.jpg http://i13.photobucket.com/albums/a2...B4591FAC61.jpg http://i13.photobucket.com/albums/a2...A8E6E1C565.jpg http://i13.photobucket.com/albums/a2...DD06CF57CD.jpg http://i13.photobucket.com/albums/a2...4B9849466C.jpg http://i13.photobucket.com/albums/a2...AF724372C6.jpg http://i13.photobucket.com/albums/a2...41A035F2BC.jpg |
Very Nice. The intake came out great.
I have been asked by a few people to compile a list of parts required to to a "B" body LS swap.......I'll try...............LOL.....
GM Connect and Cruise assy or equivalent ........The GM set-up consists of mostly everything needed (engine , trans, torque converter, sensors, harnesses, engine and trans controllers, O2 sensors and Bungs, Etc) Motor Mount adaptor plates that raise the engine 5/8" to clear the cross member (made by me.....If interested PM me) generic plates won't work Holley 302-1 Pan Kwik Performance front drive set-up GM starter I like to use a 2006 GTO 140Amp alternator (jumper cable 4 pin to 2 pin) from Speartech Classic Auto Air heat and A/C retro kit Recommended to get a Aluminum LS Radiator assy with dual fans (your choice) Dakota Digital VHX gauges Dakota Digital Fan Controller Dakota Digital OBD module to feed the gauges directly from the ECM you will need to move your Trans Cross member frame mounts back to suit your drive shaft will need to be shortened or made new A new fuel system will be needed......Tanks makes an economical set-up including Tank, Fuel Pump, Fuel level sender, and filter regulator....or you can go with advanced technology using a Ricks tank set-up with a Vaporworx pump controller New fuel lines and fittings Probably forgot a lot but I will update as I remember |
Your radiator hose doodads? Shift linkage? Credit card?
Won't ecm control fans? Headers optional? |
ECM will control the fans. I got nothing else... Andrew |
With the Dakota Digital fan controller it is way easier to run two fans with separate on/off temperatures and tie into the AC system. Since the fan controller runs off of the OBDII port (CAN) that gets a signal from the CTS anyways you have the same accuracy with more adjustability for the end user.
If you have a single, one speed fan, use the ECM and tie the trinary switch into the relay. If you have easy access to tuning software and can add some wires to the EFI harness, use the ECM, PWM, and an AC pressure switch. |
| All times are GMT -7. The time now is 01:21 AM. |
