-   -   Norwood (https://www.lateral-g.net/forums/showthread.php?t=36443)
intocarss 10-25-2012 10:09 PM
Put some timing in that thing and fire her up already
Sieg 10-25-2012 10:10 PM
:rofl:
I was thinking of you and cranked it an 1/8 of a turn........she said she had a head ache.
intocarss 10-25-2012 10:25 PM
Originally Posted by Sieg (Post 443134)
:rofl:
:thumbsup: :rofl: :rofl:
Today I had to get a 1956 T bird running at work. I was told "she's good to go"! I fire it up and cough, spit, backfire, sputter & stall. I ask if the Timing is correct?? I am told.... "YUP IT IS" I fire it again and cough, spit, backfire, sputter & stall, I put a timing light on it ... I grab ahold of the dist and turned it about a 1/2-3/4" advance (Not telling you to do this)..... she purred like a kitten.. Then had to set points gap and dwell WOW how old am I last time I set points I was 19 and it was my own car LOLOL
FETorino 10-25-2012 10:32 PM
I'd say hell yea
You could run a locked out dist and start it with 36 deg of timing if your starter is up to it so more timing should be your friend.
Vegas69 10-25-2012 10:36 PM
This car still doesn't run?:lol:
Compression, Timing, Fuel, Spark,
intocarss 10-25-2012 10:49 PM
Originally Posted by FETorino (Post 443138)
I'd say hell yea
^^^^^What they said ^^^^^
Sieg 10-26-2012 03:58 PM
http://4.bp.blogspot.com/--_5b7oMdw8...-Surrender.jpg
:beathorse
Monkeyless in Springtuckey :D
intocarss 10-26-2012 07:26 PM
WTF Put that flag down !! And repeat after me...A CAR WILL NOT DEFEATE ME
Sieg 10-26-2012 07:58 PM
LOL!
SEND ME YOUR F'N MONKEY ASAP!!!
I'm getting my butt kicked by Briggs & Stratton technology! :rofl: :rofl:
New parts.....
Lifters, guide plates, heads, springs, valves, cam (same grind), distributor, coil, wires, wire looms, intake, carb.........
I've altered the distributor by removing vacuum advance, installing 25* bushing, and quicker advance springs, double checked it and visually it appears ok. But these symptoms almost act like it's out of phase or is it possibly a defective distributor from the beginning.....testing methods? Weak/defective coil?
Checked one hyd. lifter and it was set approx. half turn in from zero lash.
Checked spark output on #1 plug it's not blue but strong yellow/orange?
Double checked TDC against rotor.
Cranked the p*ss out of it, starting fluid, carb squiters........wants to light then goes flat.
Cam degree wrong?
I may just have to take it to the shop that assembled it and say have at it boys. Conveniently they're right across the street from the body shop. :thumbsup:
intocarss 10-26-2012 08:04 PM
The Monkey is on his way!! BUT remember he's retarded, (for the PC people it means "mentally challenged") so who knows where he'll end up. Now turn that dist 1/2" CCW and try again
HEY,, would it help if we put a kick starter on it??
