http://i291.photobucket.com/albums/l...nca/seig-1.jpg |
We know how the Camaro vs Mustang thing pans out, but we ain't played Camaro's and Torino's yet have we? :D |
I hope the RESISTOR wire doesn't go to ANY resistor unless you're so old fashioned that you still have a points distributor...
I'm beginning to wonder is you have power (Ignition) after you release the key... so you have power while you're in crank/start mode - and you're dropping power in the "run" position? That would drop power to the coil... and kill any hopes of firing off. Just thinking out loud here. |
The key circuit is a very good thought.......I'll research that tomorrow. In reflecting on my trouble shooting I've focused more on problems and solutions than symptoms and probable causes at times.....if that makes sense. Thanks :thumbsup: |
I'm wondering which engine harness was installed in the car and what alterations could have been made. I need to confirm the brand, part number, and optional harnesses and blueprint the current configuration.
:goofy: |
Sorry, I thought I had read that you had spark earlier.
Maybe run 12v from the battery straight to the coil and see if she fires. you'll have to remove the 12v wire from the battery for it to shut off
Haven't had a chance to work on it today, busy building the relationship with the Dane in anticipation of adoption. I want to thoroughly understand what's going where with that engine harness, there was a yellow wire that was altered by the body shop :_paranoid |
| All times are GMT -7. The time now is 03:49 AM. |
