I can tell you they can be modified to fit if they dont with no problem. Even on my 64 one of the fender holes would come forward and enlarge the slots in the hood by about 1/4 of in. closer together and they will work. I can check a 65 or give you the measurements on the hinges if you need them. |
So basically the center to center on the hood is "closer" and the hinge is "wider" . So I'll "oblong" the slots on the hinges with the lathe so that they are closer ?
On the 64 Chevelle the fender mounting section and pivot points appears identical to 67-69 Camaro. But the top piece that bolts to the hood is completely different and would need it's own designated piece. In addition to the holes being closer the shape of the hood mounting area is not flat, it's offset, so the piece would need to conform to that. Jody |
Like I said in Columbus, good stuff Fesler! Looking forward to a set for our 67 Chevelle.
Dealer apps
We have the dealer application ready to go so if you are intersted in becoming a dealer please email me your email address and I will forward it over to you. thanks
I didn't see the 69 Camaro one's on your site. Are they available now. I need a set quickly.:thumbsup:
69 Camaro hinges
Yes they are available now
Wow, so cool! Anyone know if the Chevelle hinge can be made to work on an Olds Cutlass/442? :unibrow:
Shiny Side Up! Bill |
I Think A Pair Of Polished Or Chrome Hood Hinges Would Look Really Good On My 2nd Gen!!!
| All times are GMT -7. The time now is 04:45 PM. |
