*Insert obligatory nut joke here*
http://lh4.ggpht.com/_7EUAij74Ycw/S_...0/DSC00036.JPG http://lh3.ggpht.com/_7EUAij74Ycw/S_...0/DSC00038.JPG Missing the centering ring underneath the nut, should end up looking something like this when it's all stacked on there. http://lh5.ggpht.com/_7EUAij74Ycw/S_...0/DSC00035.JPG Large nuts or small hands? You be the judge. http://lh5.ggpht.com/_7EUAij74Ycw/S_...0/DSC00037.JPG |
Started on the front uprights:
http://lh6.ggpht.com/_7EUAij74Ycw/S_...0/DSC00045.JPG http://lh5.ggpht.com/_7EUAij74Ycw/S_...0/DSC00046.JPG Should look something like this when they're done: http://lh5.ggpht.com/_7EUAij74Ycw/S_...00/upright.JPG CTS-V/C5 Corvette hubs bolt in to the center hole. Camber adjustment is done by swapping the rectangular shims up top. |
Can't wait to see the uprights welded up and installed!
--Eric |
unless you hard anodize the centerbolt adapters and nuts i would be worried about gouging... the thread should in to teh best of my knowledge be made in steel so the aluminum dont fuse then you try and loosen/tighten it..
I have an alfa corse spindle from a 93 DTM alfa and its made in thinwalled steel for teh same reason i suspect... |
You guys definitely know how to design/machine some sweet parts. Its going to be heck of a Volvo. :thumbsup:
All four adapters are finished. Alex really did a great job on them. http://lh5.ggpht.com/_7EUAij74Ycw/TA...0/DSC00055.JPG Got the centering rings back from anodizing: http://lh6.ggpht.com/_7EUAij74Ycw/TA...0/DSC00047.JPG All bolted up: http://lh3.ggpht.com/_7EUAij74Ycw/TA...0/DSC00048.JPG http://lh3.ggpht.com/_7EUAij74Ycw/TA...0/DSC00049.JPG Final weight: http://lh3.ggpht.com/_7EUAij74Ycw/TA...0/DSC00050.JPG Progress on the front uprights: http://lh5.ggpht.com/_7EUAij74Ycw/TA...053%20copy.jpg |
Amazing. Those look great! Looks like tigging in those cross peices on the uprights is gonna suck haha. :thumbsup:
This fabrication work is awesome, good job on not only the research & modeling, but carrying through with it too.
And hip hip hooray for Solidworks, anything you can dream up can be a reality when solid modeling!! |
| All times are GMT -7. The time now is 04:06 PM. |
