-   -   pro touring 69 camaro project (https://www.lateral-g.net/forums/showthread.php?t=25177)
millertime179 05-31-2011 07:39 PM
Originally Posted by DJW32 (Post 350781)
What size are the front and rear tires? 275 & 335?
Any chance we can get some pics of the rear suspension?
Great looking car!
the fronts are 275/40/17 and the rears are 315/35/17. there should be some pics of the rear suspension earlier in this thread or you can check out shannons thread under chassis and suspension (scott mocks rear suspension)
kevin
Jr 05-31-2011 09:32 PM
This thread doesn't have any pics of the rear suspension. Modo's thread doesn't have any installed pics, either.
coolwelder62 06-01-2011 05:41 AM
I will get Kevin to bring his car over to the shop and we will get some photo's of the car and the rear suspension up on the lift.So everybody can get a real nice view.
Rick D 06-01-2011 07:19 AM
Cool Scott looking forward to seeing it installed!! :thumbsup:
syborg tt 06-01-2011 09:46 AM
Hi Kevin,
Car looks great
I do have a question.
What exhaust manifolds are on the motor ?
coolwelder62 06-01-2011 11:36 AM
Originally Posted by syborg tt (Post 350974)
Hi Kevin,
Car looks great
Those are the stock LS1 manifold's.W/jet coating.
millertime179 06-01-2011 03:45 PM
Hi Kevin,
Car looks great
they are just stock manifolds off a 98 trans am. they are tube welded together instead of cast iron so i had them jet coated and just used them for now to save a little money. hoping next winter to do a little motor work and then ill put some headers on it.
thanks kevin
gasfumes 06-05-2011 07:24 PM
What motor mounts and adapter plates used on subframe?
millertime179 06-06-2011 03:14 PM
the motor mounts are energy suspension poly mounts and we machined the adapter plates out of aluminum.
kevin
Jr 10-11-2013 09:12 AM
Kevin,
Did you upgrade the front suspension in the 69? If so, do you have any pics? What size wheel tire did you fit in there?
