Hi beam switch
Clint, Do you guys move the high beam switch a little to get the kick panel to clear? I know the factory parking braket gets trimmed. Thank for the photos your stuff looks awesome
Installed the kick panels in my '68 Camaro and they look great the speakers sound awesome as well.
Below is my feedback on my install:
https://lh3.googleusercontent.com/7m...8=w748-h997-no https://lh3.googleusercontent.com/pC...w=w748-h997-no https://lh3.googleusercontent.com/4y...=w1328-h996-no |
Adam, can I ask you a question (off topic) ? What rubber sleeve did you use for the clutch rod going through the firewall ?? I have the McLeod hyd set-up and was looking for something to go over the rod and cover the hole. Thx man.
Sorry, bought the car with the T56 already installed. I'm fairly certain the whole clutch setup was sourced from Hurst Driveline, so might try calling their tech support line. Looking at the invoice, the master cylinder part# was T75-750U.
Thank you!!!
Awesome install and love the feed back! Thanks a ton! |
20% off till Monday
Be sure to check out our online shopping cart with all the latest and greatest on audio combos. Call us up with any questions at 954-440-0251 Thanks a ton!
https://the-shop-llc.myshopify.com/collections/all https://the-shop-llc.myshopify.com/collections/all http://i281.photobucket.com/albums/k...E%20STEREO.jpg http://i281.photobucket.com/albums/k...ROCOMBO012.jpg http://i281.photobucket.com/albums/k...RAYCOMBO-1.jpg http://i281.photobucket.com/albums/k...E%20CAMARO.jpg https://the-shop-llc.myshopify.com/collections/all https://the-shop-llc.myshopify.com/collections/all |
| All times are GMT -7. The time now is 05:13 PM. |
