Spoke with their customer support earlier today. They are shipping me the replacement parts now and I'm looking forward to checking this off the list!
Hate to hear about all the problems you're having with parts not working out or needing to be replaced. But on the other hand it's nice ce to know I'm not the only one.
I love those Wilwood hubs, it's a shame to cover them up. And by the way, just ran a not the same issue with valve stem interference just this week.... |
What are you doing for your valve stems? Just the end is hitting so I'll get something shorter I hope that will work. |
There's a couple options. One is a half-height stem which measures 3/4" from the outer wheel surface to the end.
Second is a button type valve which is a bump maybe 1/8" high which will definitely solve the problem but it's a pita to use. You have to unscrew the cap (button) and screw in a valve stem to adjust pressure. The screw in valve stems are small and are easy to misplace, but they do work. Both are available at Jegs/Summit |
Looks like I need to take some measurements tonight on the valve stem. It Just clips the top of the caliper at the front and in the bar across the middle and again at the back, so slowly roating the tire I can hear three distinct clicks as it hit.
Working with Wilwood now and may go to a different caliper up front if I can work it out financially with them. |
Ihad a similar problem with valve stem in Rushforths hitting calipers on 14" Baers. Luckily I checked before having tires mounted. I used the 3/4" metal valve stems. Think I got them from Speedway.
Those wheels... Yes! :thumbsup: :thumbsup:
I'm out of town for the week but I got the exhaust in, with the exception of one small pipe that was missing. It really turned out nice. Took a few of the motor as well just for fun...
http://i213.photobucket.com/albums/c...psnj8t0pxz.jpg http://i213.photobucket.com/albums/c...psbv7t9sfg.jpg http://i213.photobucket.com/albums/c...psyshmlavw.jpg http://i213.photobucket.com/albums/c...psumfzrats.jpg http://i213.photobucket.com/albums/c...pseckwodeu.jpg |
We are big fans of those wheels. How big is the dish on the 12s?
| All times are GMT -7. The time now is 10:53 PM. |
