How does the EZ efi determine what AFR the engine will run at? We use the heck out of the new Holley HP system, it is self learning and tuning, but we still have to determine the AFR we want it to run at
Most people... even experienced tuners miss this one because they don't understand how it works. |
No, for it to work properly... and if you actually did some testing with the injectors and saw what they did when you didn't reference them... you would know why.. For the EZ EFI it is a must since the ECU uses fuel pressure as a reference.
Really all efi systems should be this way. People get lazy or think there is no reason for it but there is. So, if you understand how it works then your saying it is correct for the injector to flow more fuel at an idle than it does at WOT? |
I am not challenging your knowledge, I'm just a home hobby tuner guy. I just can't see the issue you're describing. |
So, really the reason you touched on is the injector flow... yes they have a minimum time it takes to open "dead time" but what we want it to keep the pressure differential across the injector constant so we just tune the fuel curve and not chasing an injector that flows different amounts of fuel at different engine vac. when you do not reference the regulator here is what you have. At idle and cruise when you have hi vac the injector will actually flow more fuel without the line connected because the pressure is say 45psi and under vac to it helps pull fuel out of the injector, so....net you have more fuel flow if you have no vac reference. So 45psi and -10psi equals a net of 55psi flow... the injector will flow more fuel in this vac area without the line connected. The problem is worse as the injector size gets larger. Now if you do reference the regulator you have 45psi fuel pressure... and say -10psi vac you have 35psi fuel pressure and -10psi still equals 45psi net... the injector flow rate stays the same. As the injector sees less vac then it keeps the same net flow rate across the injector no matter what the engine vac or boost does. That is why you actually boost reference the regulator... so the boost does not push the fuel back into the rail. 45psi... 10psi boost 45psi + 10psi = 55psi but still a net of 45psi fuel pressure since the intake has 10psi in it. You will find that if you use the vac referenced regulator and actually use it all the time it will make tuning easier. Now "opening time" or "dead time" is something totally different... it is the minimum actual time it takes for the injector to open and start flowing fuel.. That is a different table and not a table for tuning... it should be a compensation for each style of injector. If that table isn't correct then when you ask for a 5% change in fuel you may only be getting a 3% change actually. Having a referenced fuel pressure regulator effects the opening time some since the vac makes it easier to open the injector but that is part of the reason the reference helps there too. Most aftermarket ECUs only use injector dead time as a reference in voltage vs time and don't take in account fuel pressure as a third axis. GM does in the KPA vs flow rate in the LS computers. And a second table as injector flow vs battery voltage. Injector dead time/opening time is a value added back to the commanded injector pulse width that is programmed into the ecu... it is even more important as RPM gets real hi and the actual time to get the job done gets shorter. Now that we said all of that... the EZ EFI especially needs this because when you enter the fuel pressure... it assums that the given pressure is at rest with no vac line... that decided how much pressure you have off what the map sensor shows. Then it decides how much PW it needs to maintain a target A/F ratio. It will have a harder time tuning itself when it is assuming the fuel pressure is lower than it really is. |
Boosted I reference it, N/A I sometimes do and sometimes don't. I like to run rear-mounted regulators too so that's a whole 'nother area we might argue about........... :D
I appreciate the info. |
Brian --
Good discussion! So.... if the A/F ratio is set for 14:1 and the actual, and set, match - what possible difference does it make? I.E., you set the idle A/F and the ECU with the help of the O2 sensor makes sure that's where you're at.... I would ASSume then that the PW is properly set/adequate etc for the situation? |
I gotta say this, these type of threads can contain the best information. And Brian, I'm not trying to be a Jackwagon. :lol: A debate over this stuff is better than a lot of other things! :thumbsup: |
I do totally disagree that the vac line does not have to be connected to the regulator in the EZ especially.. it will run rich in most cases if you do not do this. If you switch it from not hooked up to hooked up then it will take time to learn out the areas where it was trying tune around the perssure differential. The more vac the engine makes the more this will be a problem. I am saying this for the exact reason you are saying it "does not matter" so other people on the board that read this do it the right way and don't try to over think it... like you said if you wanted to know this then you would buy a tuning EFI system. In this case just follow the directions and don't think about it. When I do things... especially EFI.. there is only one way to do things.. the right way. This is a clear cut right way to do things, so why would you do it any other way? |
PW proper... no.... works yes... here is why. Without the regulator hooked up and lowering the fuel pressure to maintain the same flow, the ecu has to trim out the extra fuel and really lower the numbers to get there. It sometimes can do this and sometimes cannot. There are several guys complaining about having engines that run too rich and the EZ will not tune it out. Most have found this when there was no vac line connected. If you read the CPG Nation board.. this is one of the basic settings people mess up. I had a shop in your neck of the woods calling and calling me, since I was up there... had a EZ... one of Bobs... 10 different people whith o scopes looked at it and no one could get it to run... I went and reset the wizard.. went through the screens... hooked up the vac line and wow it runs without any black smoke. They were also told there was no need to hook up the line.. not true. You understand what the regulator is actually doing? Correct? The rear mounted regulators... yeah.. another problem there.. I had two burned up offroad cars because of that last year. |
Again, we're just discussing your claim that the reference line must be used. I was speaking of all EFI, but even with the EZ Efi I'm not sure I agree. It's obvious many people have them running fine without it. Is it a good idea to help it self tune, apparently so. A "must"......... no. I have tuned too many EFI systems without it to agree. It's all semantics. When you speak in absolutes you'll invite people to give examples that contradict what you're saying. If you said that the system is designed to have the reference line attached, and it helps the computer learn the tune much faster, I don't think that anyone would disagree with you. It's the absolutely "must have" wording that doesn't fly, because we have examples of that not being true. |
Why won't this work? Well, it will, but curious why you think it's wrong. One of the main benefits is eliminating all that hot bypassed fuel from heating the tank and leaving you stuck on the side of the road (ask the dozens of Power Tour cars that experienced that from year to year how much fun it was). |
Even with running the regulator in the front and looping the rails can show as much as 1 AFR point from side to side. What stops the fuel from just bypassing the fuel to the tank insead of going to the engine? It will follow the easiest path. There are other ways to dealing with hot fuel than bypassing it in the back. bypassing in the rear works for a low performance engine but when you start to get something that really needs fuel flow it will not work. You will end up with burned valves and or broken pistons. |
Look at all the OEM pump engines that don't use PWM pumps and they all have vac referenced regulators... OEM changed to that in the early 90s. It is an absolute. Must have and the right way. If you don't agree then you are saying the injectors should flow more fuel at part throttle.... and you already said that isn't the case. Besides how hard is it to hook up a vac line? |
My Cobra was n/a and had a front regulator, but still no reference line. Ran fantastic. All of these cars had O2 bungs on both sides and the sides were always within a couple tenths in A/F; nowhere near a full point difference. That was with comparing the computers wideband to the in-dash wideband gauge, to the handheld Innovate. As far as fuel taking the path of least resistance, it seems like you'd see the pressure issues on a gauge. I have the gauge on the rail, and on the regulator, and I am not seeing any movement, fluctuation, or dropping pressure on mine.Seems like the regulator is working fine if the pressure is dead steady, a/f basically match side to side, and the car runs great. I do not doubt what you've seen, just that I do check and don't see it on mine. A/F differences from side to side can be due to heads, intakes, etc. as you know. Interesting that you've seen a difference with just moving a regulator. I've just been doing it a different way and my stuff runs good and doesn't blow up. And I never do a mild engine................ :lol: Again, it's just the "must" wording that I cannot agree on. |
This is the whole key... think of it as a straw that you blow through.. if you blow normal with no pressure or vac then you blow x amount of air. (WOT sea level 0 vac and 0 pressure) If you have a suction on the other side and blow the same pressure then you actually get more air through the straw. (engine vac) If there is someone blowing on the other side of the straw then you need to blow more pressure than they do to get the same amount of air out the other side. (boost) So the way you are tuning is... there is actually more differential pressure at idle and cruise (more fuel flow)... then you lower the PW more than you should have to since the line is disconnected.... then you chase the fuel injector fuel flow change AND the VE air flow through the table while you are tuning. This will get you in big trouble when you have say a 4.6 mod engine with 160# injectors that makes decient engine vac at part throttle. You can't lower the PW enough to make up for the extra flow the injectors are flowing.... It is a must and the correct way to do it PERIOD... if you say it isn't then you are just passing bad.. efi info around yet again. It is the exact same reason you boost reference the regulator... and everyone does that. |
Appreciating the dialog gentlemen, and learning a lot. Keep it up! :thumbsup:
If you really think you will see pressure drop on a gage you are kidding yourself.. you lose fuel flow long before it actually hits the gage. By the time the gage actually moves you are OUT of fuel. |
Brian --
I'm calling Brizio to have him hook up a vac line to the pressure regulator.... Well -- maybe not -- this is something I'd rather do myself. When the car was built - the line was run - just not used - so is a simple deal now. SMART HUH?! Just 'cause the next time I see you (SEMA) I can say I did it right.... ">) It all makes "sense" --- but on a little crate motor... I'm doubting it changes much... but then again -- I'm TOTALLY ready, willing, and able, to learn. You'll never hear me say that I know it all. |
I have not had a single idle issue yet doing it my way. I've never had the pulsewidth go "too low" at idle and cause issues. I've never "chased" the tuning because of this. You seem to take it personally that I have made it work well in a way different than you think it should be. You've given good advice, I see the purpose of referencing the regulator. But with a rear mounted regulator it's just one more line to run, plus I'm not sure there may not be an issue with the length of the line. Couldn't see an issue with the forced induction builds and the line length, but never tried on N/A. I don't try to hand out bad info, I simply try to help with things that work for me. I have no problem with your view and would recommend people follow your advice, you're the pro. What I don't agree with is you keep saying that the reference line must be used. That's where you lose credibility. It's obvious that it isn't required or none of my cars or any of the other examples in this thread would run. I mean, they wouldn't even start up according to the "must" claim. That's my point. |
I'll stick with Jody's tuning. I know his works well.
Since this is clearly Brians meat an potatoes, I'm sure he knows what he's talking about. With that said, there is perfection and damn close. Engines don't require perfection to run well or cars likely wouldn't exist. I'm pretty certain my 850 holley isn't perfect. :D
We'll agree to disagree on the definition of "must". ;) |
Jody :thumbsup:
It's not my credibility... it would be yours to keep arguing that it really does not matter. If you really understood what was happening you would say... I will always do it that way now that I understand. To tell people bad information that is does not matter or everyone here has always done it this way and it worked isn't a good argument. I never said an engine wouldn't start.. or run... just not "right" most EZ EFI systems wont run very well at all. The real problem is where you try to lean out the idle down around the 1.2-1.4 ms of PW and you keep getting a rich condition you can't get out. Like I said, you can machine an engine with .008 piston to wall clearance.. would it run.. sure.. but would you do that? No.. So if you now it is better and the proper way to run the regulator with the vac line then why wouldn’t you? Lets face it the industry is full of people who see one thing and copy everyone else who is doing it that way. If the points leader uses brand X oil then it must be the best stuff out there. If this guy uses these gaskets then everyone should use that gasket. There is more bad info out there than there is good especially in the EFI world. My day usually consists of helping people tune their stuff after 5 other guys just took their money and gave them the tune out of the XFI folder. Part of why I have done well as a EFI tuner is I do a lot of dyno testing trying different stuff and have access to some really cool datalogging stuff most people don't even get to play with ever. I try to help out on a few boards and offer advise on what works and what does not. If I see something people don't get or understand then I try to help them in the right direction at least. This topic is something that I cover in every EFI101 class I teach and usually get blank stares from the students that say... wow everyone else does not do that. When I draw a picture on the board... most get it. There is lots of other stuff like, adding fuel stops detonation.... fuel is power... lots of stuff we debunk on the chassis dyno live at our classes. Not taking anything personally and not talking down to anyone just trying to educate some bad info. |
I've been doing my own tuning since 1994 when I had a program to burn my own proms. I have done many N/A cars with and without reference lines. Not a single one had an idle issue or tuning issue. I have seen countless other cars in that period of time that didn't use one and ran fine. I am not challenging your knowledge. I can see why you want the reference line there. It makes sense to me and I'll start using them again on the N/A stuff. The only reason I didn't use them is because of the rear mounted regulators I use, and I was told by a tuner that the length of line would cause tuning issues. So thank you for telling me it won't. The only part that we disagreed on was that it is required on all EFI systems. If you would have said it's the best way to go and here's why, it can help with the EZ EFI if you have a fat idle and can't get rid of it, or if you're dealing with a large injector and having idle issues this can help we would have had no disagreement. My only point was on the "must" part of what you were saying. Hopefully you get what I'm saying, because I really can't explain it any better. Thanks again for your time and info, it is appreciated. |
I say "Must" because it is the right way to do it for no other reason. I still think even after all the posts you still don't get it. It's not lowering the pressure but more the reason is the pressure differential between the intake and injector remain the same, no matter if you are in boost, vac or no vac.
Do you get that part? Then the ecu just tunes the actual fuel curve and not the fuel curve and the pressure differential too. This gives the ecu a better ability to tune at the lower PW for any injector size. If line length was an issue then your rear mounted regulator wouldn't work under boost. The long line will make the change slower but it will still work just the same. |
Go Steelers! How's that for agreeable Jody? |
| All times are GMT -7. The time now is 07:04 PM. |
