I put my son Josh to work today helping me get the front end back on the car so we could push the car out and turn it around to finish up the 4-link and get the new rearend under it.
http://i1158.photobucket.com/albums/.../null-2194.jpg http://i1158.photobucket.com/albums/...o/null-563.jpg http://i1158.photobucket.com/albums/...o/null-940.jpg http://i1158.photobucket.com/albums/...o/null-395.jpg |
Since the car has no rearend under it it's sitting on a floor jack and 2x4's so I could measure the rearend width.
http://i1158.photobucket.com/albums/...o/null-452.jpg |
keep up the good work,that subframe looks really nice,like the wheels too:thumbsup:
I like the wheels. Nice job on the subframe.
Your doing an excellent job on this build:cheers:
My dad layed out the rearend for me based on my measurements. Hopefully I didn't screw up. I made a run down to his house tonight to drop off the Wilwood brake kit to be safe. There's a lot of variables when considering a 1" offset pinion on an offset center section on a rearend with different axle tube lengths and throwing a disc conversion in the mix. :headscratch: :headspin:
Too much for me. I left it to the professional. I can't wait to see this thing in the lathe getting cut down. |
I fixed the passenger side door. Removed the old skin, sanded and wire wheeled the inside and painted with SPI black epoxy to protect before reskinning.
http://i1158.photobucket.com/albums/...o/null-766.jpg |
AMD skin? Looking good.
oh,thats easy,
We re-hoop'd the wheels to get better fender clearance with the new front brake kit and to go a little wider with improved scrub radius and front/rear track offset. I added 1/2" width and moved them in 1/2". The front wheels are now 9-1/2" wide with 6-3/4" back spacing. (Was 5-3/4 BS. Now 6-3/4 BS going from a 7" inside rim half to an 8")
http://i1158.photobucket.com/albums/...o/null-301.jpg http://i1158.photobucket.com/albums/.../null-1948.jpg |
Coming along nicely. I'd say you've done a good job of fixing the body considering how bad it was when you started.
Incredible work! Wish my car looked half this good
Looking good!!
Thanks guys. Seeing your builds keeps me motivated. There's so many cool cars on here! At times it seems like I have a long way to go but progress is progress and I'll eventually get there. Even when it's just a little at a time.
hows that rear suspension coming along?
Damn, well let me know if you need some input and a bare moser housing. Much easier route if you don't mind forking up 460 for a bare housing
My dad messed around with it today and figured out a solution. He turned the tubes down a little and made the bracket bores a press on fit so it will work out. Fortunately this rear end has the thicker 3.25 diameter tubes. |
I don't have any good pictures to post but have made a little progress. All of the 4 link brackets have been machined and the new axles are here. I wasn't able to use the Wilwood offset bearing retainer with the new updated bearings i got from Strange. The new A1013A bearing is wider so I picked up some flat retainers from AME yesterday. I also picked up the 1" .156 wall DOM tubing for the links themselves.
My buddy mounted up my 245's on the wider wheels. They're a little stretched but work to my advantage for fender clearance. I'll take a look at 275's later. http://i1158.photobucket.com/albums/...o/null-408.jpg |
Those 245s don't look too bad. If clearances are really tight, a 255 might give a good balance. 10mm makes a lot of difference sometimes.
looking good, let see the rear man!
Wheels look killer... I'd also recommend trying at least a 255 tire on there if you can.
Seems like forever since my last post. It's been a busy end of summer. Sent my baby girl off to college, bought a new car, moving, works crazy busy, a few birthday parties, kids sports,.. Stuff you guys know all too well.
I plan to spend more time in the shop in November. I did however finish up the 4-link pockets. The rear ends in the car finally. I'm happy with how it turned out. The axle tubes are within .010 on the dial indicator now. Phew.. That was stressful. I never realized the factory 9" rear ends had such large tolerances. Mine was almost .050 out on one side before we started on it. I should be hauling the car down to my dads in the next few weeks to throw on the lift and finish up the bottom side and mock up the engine and trans. |
Here's some pics of the 4-link pockets. I second guessed myself at least half a dozen times on the design and location. Luckily I had Brendon to keep me straight.
http://i1158.photobucket.com/albums/...ps862eb3a2.jpg http://i1158.photobucket.com/albums/...psaab4ec3a.jpg http://i1158.photobucket.com/albums/...ps89110c67.jpg http://i1158.photobucket.com/albums/...ps2ca6bcb4.jpg http://i1158.photobucket.com/albums/...ps99edffd6.jpg http://i1158.photobucket.com/albums/...ps1d7c9b38.jpg http://i1158.photobucket.com/albums/...ps8de69a4a.jpg |
I tweaked the rear end geometry and brackets so many times I lost count. After debating over and over and factoring in excellent advise from successful racers like Ron a Sutton and my dad I ended up settling for two different anti-squat configurations. One for road race and a second setup for drag. I'm not 100% sold on arch slotted brackets so I went with multiple holes. The pan hard bar will be slotted as the load is perpendicular to the slot.
Here's some of the brackets off the CNC mill. http://i1158.photobucket.com/albums/...ps5476f1c9.jpg Here's the round stock and bushings my dad turned in the lathe to be able to setup the rear end. We bolted the 3rd member into the housings with shims the same thickness as the thinner gasket to locate the bar which we used for reference with the dial indicator to check the housing ends before I welded them on. We reused the old ends and turned them down to make a step in the tube side to locate them on center. I took most of the pictures with my dad's phone. This is all I have at the moment. http://i1158.photobucket.com/albums/.../null-1437.jpg http://i1158.photobucket.com/albums/...ps9cb190c5.jpg Here's the spacers that go between the brackets and the heim ends. I used 5/8" heim joints with a 3/4" shank and turned and cut left and right hand threads in 1" .156 wall 1022 DOM tubing I picked up from Morrisons shop. http://i1158.photobucket.com/albums/...psc2793361.jpg I set the wheel base to 108". 2 deg pinion angle with the holes in the outside brackets at 90 deg (vertical/plum) and the bottoms of the inner brackets at 0 deg (level) http://i1158.photobucket.com/albums/...ps0aded64b.jpg Here's the finished width. I was barely able to squeeze the 11.5" wheels with 315's in there. The rear end articulates well with a rolled edge on the inside lip of the fender. http://i1158.photobucket.com/albums/...ps9d9f9eb4.jpg |
I installed the trunk lock and threw the front fenders back on to get an idea of the stance. ;). It's been a long time since I've been able to push this thing around on its own 4 wheels. It was nice to get it outside.
http://i1158.photobucket.com/albums/...ps8b41cb67.jpg http://i1158.photobucket.com/albums/...ps456011f6.jpg |
I like your wheels and the stance is real good,keep up the good work,really nice.:thumbsup:
Thanks Jeff. The guys at Fikse did a great job for us! This new design will be available soon. I'm really happy with it. They've got a lot of good things going. New designs, more hoop choices and bigger wheel sizes.
| All times are GMT -7. The time now is 10:28 PM. |
