| Matt@BOS |
10-17-2010 10:55 PM |
Originally Posted by flash911
(Post 311639)
They are not on the website and you can buy them 'ala carte'. Just call them up and ask for the parts. They come in 120 DOM and Chro-Mo. IIRC, the DOM's are in the $300 range plus shipping...
Speaking with a number of guys smarter than me, without A piller cage down bars all I would be doing by installing these is adding weight and flexing the firewall. I know BOS and JCG Chris made some really awesome brackets for the down bar firewall mounts, but I've decided to wait until they get mounted and tested before doing any downbars.
(edit: credit here goes to AME Matt and RideTech; both said the same thing. I am wondering if the Hotchkis version does any better?)
Having said that, they do look hardcore and I'd love to find a reason to buy them...
Ron, I think you're pretty much right on with everything you said. I seem to remember the '69 DSE test car having the bars (I could be wrong) and don't recall it having a full cage. I'm hoping that with solid bushings along with subframe connectors and everything else, the body will be rigid enough that the bars will be mostly cosmetic. I'm sure it is going to sound very "show-touring" of me, but the major reason for the bars was to serve as mounts for the shock and brake/clutch reservoirs although the brake/clutch ones ended up on the firewall. I think they should fulfill that purpose, without hurting anything (they work ok for Hotckis, right?) and I'm not too worried about a couple pounds over the front. I set out to build an enjoyable driver's car that can eat up highway miles, and make a mediocre driver like myself have fun out on the track.
On a side note, I'm pretty sure Brett with the champaign/gray '67 Camaro convertible that's been running around socal lately added frame to firewall bars to support his Martz clip with what I'd call very good results. In his case, I'd guess the bars made a big difference and his firewall has proved to be up to the task of holding them.
Cris, I would have called you, but I thought the Wilwood guys were on the same page with you regarding brakes for the floater. Oh well, live and learn. I'll give you a call Monday and see what you're up to. I've got W4As coming for the rear and haven't given too much thought to a parking brake. Also, I'll check tomorrow to see how the drive plates fit to the wheel center holes. They should be cut to the same exact size, but I'll double check.
Matt
