-   Mark Stielow Builds (https://www.lateral-g.net/forums/forumdisplay.php?f=94)
-   -   Camaro LT5 (https://www.lateral-g.net/forums/showthread.php?t=60142)
fleet 12-25-2020 09:02 PM
Originally Posted by clill (Post 709180)
He could out run us in a Camray...
Agreed!
https://i.postimg.cc/26HH571z/BD9116...208-F3-CE8.jpg
:P
Rodknock 12-26-2020 03:37 PM
Just amazing. Almost makes me want to got supercharged instead of TT. That's ok, I have time!!
cpd004 12-29-2020 04:01 PM
Originally Posted by Stielow (Post 701284)
We are dry building the whole car this time before paint. Matt is putting the front clip on it now to finish the engine bay.
Just finished the dip stick for dry sump tank.
https://uploads.tapatalk-cdn.com/202...af2cafec4c.jpg
Reassembling the front end
https://uploads.tapatalk-cdn.com/202...648617bfa9.jpg
In this pic, is the long L bracket attached to the radiator custom made or where did you source it?
Thank you.
Stielow 12-30-2020 05:41 AM
Thank you.
Sorry I don’t understand your question. The picture is of the dry sump tank.
The radiator was made by C&R. The car was modified a lot to make it fit.
cpd004 12-30-2020 06:48 AM
1 Attachment(s)
Sorry...this long upper bracket here.
Thanks.
Stielow 12-30-2020 08:02 AM
Thanks.
That comes from C&R.
just_a_69 12-30-2020 08:54 AM
Hey Mark. Great build per usual...
I’m wondering how you check the oil with the dry sump tank in that location. Do you use a custom dipstick through the fitting on the firewall? Would a sight glass welded on the side of the tank work?...
Thank you for all the information and ideas you provide to this forum.
Stielow 12-30-2020 03:42 PM
It has a dip stick
https://uploads.tapatalk-cdn.com/202...13a0233f30.jpg
Stielow 12-30-2020 04:24 PM
LED bulb trial testing.
Many LED bulbs are too bright as running lights (Gordon’s Camaro[emoji2959])
I wanted LED bulbs closer to stock brightness for running lights.
https://uploads.tapatalk-cdn.com/202...63a2780522.jpg
https://uploads.tapatalk-cdn.com/202...f8f4b1ca48.jpg
https://uploads.tapatalk-cdn.com/202...71e35ee020.jpg
69Toronto 12-31-2020 03:02 AM
tailights look great, are those bulbs for the stock socket or an LED panel?
thank you
