Cris,
The third member you got from Jays black car was Moser, not Strange. The Strange unit is an S-trac. Moser is who sells the wavetrack. On a side note, there is a 35 spline tru-trac available now but im excited to see what you have done and hopefully will have available in the future. Jason |
Beat the ever living snot out of a Moser 12 bolt 33 spline true trac with not a single problem. Around 30 events and 7k street miles. Ran plain old valvoline dino oil with no oil cooler. :D Loved it...
Thanks for taking the time. I was just curious. |
Maybe I just got lucky but I have a fair amount of confidence in the 31 spline tru trac.
I didn't run it on a road course but did several dragstrip runs/etc. No issues ever. https://www.youtube.com/watch?v=9fGQiIlyHTM https://www.youtube.com/watch?v=Nm_A-Zl5d6k |
Sorry.. You are right on that one.. I have some many units lying around I can get them confused.. :lol:
We both have an investment in 9" Ford housing.. So I can suggest the Strange 12 bolt drop out center section... It is hard for me to explain in detail.. but for Auto-Xing with a car with low roll center i recommend a Clutch type unit.. It will also work great on the road coarse.. but HP can be a limiting factor.. Quote:
What I try to do now is use (even if used) OEM ring and pinion gears. I've had much better luck with a factory GM 12 bolt gear or factory ford 9in gear over anything else. |
I'm curious if anyone has any new feedback for this topic - Truetrac vs the Wavetrac. I'm at the point where I'm swapping from a 10 bolt to a 9" rear and don't know what locker to use. My car is 3500lbs with only ~500 hp at the crank but will most likely move to the 600 range in the future. I'm thinking the Truetrack is plenty for but wanted to be sure I'm not missing anything
I did find this video while searching that was interesting to me https://www.youtube.com/watch?v=lZmsY2YvVsc Steve |
Steve,
I do have the TruTrac in my car, but it will be a little while before we can actually drive it. Once I do, maybe you can get a feel for what it's like locally if you want. |
Good to know. A drive to check it out would be awesome.
Do you guys use posi then for the track or is there something better for street/track use .. I have posi in my 12 bolt now with 3.90 gears just wanted to get some input on what's best so i can make changes when all the stuff is out of the car
| All times are GMT -7. The time now is 09:22 AM. |
