-   -   Ethyl's Twins - Precision 6266 and 408 Ci (https://www.lateral-g.net/forums/showthread.php?t=42820)
camcojb 01-15-2014 09:43 AM
Originally Posted by INTMD8 (Post 529196)
Fwiw I don't think it would be a problem for you to run that. I've ran a 408 with twin 66's to 1150rwhp with an LS6 intake and 78mm throttle body and that power was right in line with other combinations we did with larger throttle bodies and intake manifolds.
Not saying the fast intake and bigger throttle body wouldn't help at -all-, just that I don't think it would be a huge difference.
I agree, not a huge difference when boosted versus N/A.
wrp 01-16-2014 10:00 PM
Thanks guys. I am wondering the merit of selling the fast and 102mm TB and going to an aluminum intake.
LSx block gets in tomorrow. Going to use the Eagle Crank and Rods I have in the 408 and add 4.125 Pistons bringing her out to 427 Ci. More importantly, the LSx will have the 6 bolt heads vice the 4 bolt heads the current LQ9 has. This will allow us to boost in the 25-30 psi range more consistently without lifting the heads.
So say goodbye 408
http://i512.photobucket.com/albums/t...ps6d79a347.jpg
http://i512.photobucket.com/albums/t...psf7e0c584.jpg
http://i512.photobucket.com/albums/t...psd8eb95c7.jpg
http://i512.photobucket.com/albums/t...ps4764147b.jpg
http://i512.photobucket.com/albums/t...psdce22fa7.jpg
http://i512.photobucket.com/albums/t...psdde62081.jpg
wrp 01-17-2014 03:52 PM
Go big Orange....
http://i512.photobucket.com/albums/t...ps61b67fbe.jpg
http://i512.photobucket.com/albums/t...ps859e6d0a.jpg
http://i512.photobucket.com/albums/t...ps600e4d27.jpg
http://i512.photobucket.com/albums/t...ps51d0c478.jpg
http://i512.photobucket.com/albums/t...ps35e6b871.jpg
http://i512.photobucket.com/albums/t...psc2ceee92.jpg
http://i512.photobucket.com/albums/t...pscd85e81d.jpg
wrp 01-18-2014 04:11 PM
Not as obvious here as when you look at it but the reluctor wheel (2 of them) have different gaps around the circumference. The wheel is loose in areas, you can tell the two pieces that had been fitted together have become unattached in areas making the assembly sort of wobbly. we'd sort of been all over the board on what the problem might be. Initially thought perhaps a burned piston. Leakdown was indecisive so we theorized that a head was lifting at higher boost. We knew we would not be sure until we had it down. Good news is that the crank, rods, pistons, and LQ9 block are in good shape. The walls are not scuffed or damaged, pistons look okay and the rods show no sign of contacting anything. Probably good thing we pulled it down when we did.
http://i512.photobucket.com/albums/t...psd2e87db6.jpg
http://i512.photobucket.com/albums/t...psdc53c487.jpg
http://i512.photobucket.com/albums/t...ps99c4eeee.jpg
http://i512.photobucket.com/albums/t...psb1e47244.jpg
http://i512.photobucket.com/albums/t...psaf445a0d.jpg
wrp 03-07-2014 09:06 PM
So we got the motor back and the heads are done. Waiting on the Turbos to return from Reed. We are going to try a 66 mm Borg Warner unit with a true T4 flange that will give us a little more support for the larger cubic inch unit.
http://i512.photobucket.com/albums/t...ps75d69748.jpg
http://i512.photobucket.com/albums/t...ps8b528f1e.jpg
http://i512.photobucket.com/albums/t...psaf7a0cbd.jpg
wrp 03-15-2014 10:44 PM
Turbos should be in by Wednesday
http://i512.photobucket.com/albums/t...ps01701693.jpg
http://i512.photobucket.com/albums/t...psba8db598.jpg
http://i512.photobucket.com/albums/t...ps6311ae1e.jpg
wrp 03-19-2014 09:03 PM
Everything is here, its all laying around the shop. Hope to have it together in the next few weeks. Got the turbos back from Work Turbochargers
http://i512.photobucket.com/albums/t...psd55d0754.jpg[/URL]
http://i512.photobucket.com/albums/t...psf41707e9.jpg[/URL]
Windsor GTO 03-20-2014 05:41 PM
Sweet ride
Looking forward to the final product. Keep the pics coming.
wrp 04-06-2014 04:47 AM
Once again into the breach!!! LSx porn
http://i512.photobucket.com/albums/t...psc1763510.jpg
http://i512.photobucket.com/albums/t...ps3d418f9e.jpg
http://i512.photobucket.com/albums/t...psd5d311a1.jpg
http://i512.photobucket.com/albums/t...ps672752e1.jpg
http://i512.photobucket.com/albums/t...ps76d452fe.jpg
http://i512.photobucket.com/albums/t...ps5f28b64e.jpg
http://i512.photobucket.com/albums/t...ps1f5c876f.jpg
http://i512.photobucket.com/albums/t...psbd859e4a.jpg
Che70velle 04-06-2014 10:25 AM
Nice! 2 questions for you. What size are you building this engine to? Does the LSX block require a special oil pan?
