You all good to go!
I can verify that the pic from Currie is correct for OEM installs. I did change mine from OEM install to get the brake caliper in front (lower CG when applying the brakes) and also keep the brake pull coming in from the front. I swapped out brake sides basically and keep the pull lever on the top ... check out the pics here from my thread: https://lateral-g.net/forums/showthr...34830&page=134 |
Looks Great :)
You really cannot mount them wrong per say. This kit is VERY versatile and can be properly installed more than one way.
Calipers can be mounted rear/front of the wheel, as well as the e-brake cable approach above/below axle tube and all depending on what side/direction the MillerBuilt adaptor is mounted. Sonar Chief took it a step further and has the caliper and e-brake cable approach on the same side. All just depends on what works best for each particular application and possible variables. |
| All times are GMT -7. The time now is 08:39 PM. |
