-   -   700 HP 1969 Camaro 540 BBC “Do-Under” Gets All New Underpinnings At V8 Speed & Resto (https://www.lateral-g.net/forums/showthread.php?t=54701)
V8TV 06-15-2017 07:28 AM
The owner wanted upgraded instrumentation in the car, so we approached the dashboard next. First, the top of the dash required some refinishing, so it was stripped, bodyworked, and then went into the paint booth for a re-spray.
https://lh3.googleusercontent.com/-p...23-16_0005.JPG
https://lh3.googleusercontent.com/-R...23-16_0007.JPG
New satin black is ready to go!
https://lh3.googleusercontent.com/-P...06-16_0015.JPG
V8TV 06-15-2017 07:31 AM
Next, a Detroit Speed steel dash face insert was used to house a full set of Autometer Carbon Fiber Gauges. We’ll install Volts, Fuel, Speed, Air / Fuel, RPM, Oil Pressure, Temp, and Vintage Air A/C controls in this panel.
https://lh3.googleusercontent.com/-q...17-16_0001.JPG
Design sketched out
https://lh3.googleusercontent.com/--...17-16_0002.JPG
Measure 3 times!
https://lh3.googleusercontent.com/-n...23-16_0008.JPG
Holes cut, A/C control going in for test fit
https://lh3.googleusercontent.com/-E...23-16_0009.JPG
All holes cut, bodywork done and sprayed in satin charcoal to compliment the trim colors on the car.
https://lh3.googleusercontent.com/-2...06-16_0011.JPG
Note 3 LED light holes above center gauge for turn signals and high beams.
https://lh3.googleusercontent.com/-O...06-16_0013.JPG
All gauges installed and wired, with a weatherpack connector for easier installation.
https://lh3.googleusercontent.com/-H...07-16_0018.JPG
V8TV 06-15-2017 07:33 AM
Tyler says “Ta Daa!”
https://lh3.googleusercontent.com/-p...07-16_0019.JPG
https://lh3.googleusercontent.com/-g...07-16_0020.JPG
https://lh3.googleusercontent.com/-L...07-16_0021.JPG
All new Dynamat sound deadener installed throughout the cabin.
https://lh3.googleusercontent.com/-o...20-16_0001.JPG
https://lh3.googleusercontent.com/-I...20-16_0003.JPG
New dash panel installed with headlight and Detroit Speed / washer switches mounted below.
https://lh3.googleusercontent.com/-_...20-16_0005.JPG
V8TV 07-10-2017 06:24 PM
The dash pad changed colors to black, and the rest of the interior was reinstalled.
https://lh3.googleusercontent.com/-j...30-16_0002.JPG
https://lh3.googleusercontent.com/-B...30-16_0003.JPG
Trunk carpet reinstalled
https://lh3.googleusercontent.com/-h...30-16_0004.JPG
There was a thought to go with a carbon fiber Anvil rear wing, but the owner decided against it and went back to silver.
https://lh3.googleusercontent.com/-n...5-16_0011_.JPG
It looked cool, but it’s all a matter of personal preference.
https://lh3.googleusercontent.com/-8...05-16_0036.JPG
Finally the wheel tubs were detailed with epoxy, and Imron.
https://lh3.googleusercontent.com/-B...17-16_0005.JPG
V8TV 07-10-2017 06:26 PM
We set the ride height and had the car aligned, put a new base calibration in the Holley ECM, and took it out for a spin! Looks sweet!
https://lh3.googleusercontent.com/-K...18-16_0035.JPG
https://lh3.googleusercontent.com/-B...18-16_0047.JPG
https://lh3.googleusercontent.com/-T...18-16_0060.JPG
https://lh3.googleusercontent.com/-y...18-16_0070.JPG
V8TV 07-10-2017 06:31 PM
Tow loop added
https://lh3.googleusercontent.com/-S...20-16_0024.JPG
https://lh3.googleusercontent.com/-M...20-16_0021.JPG
https://lh3.googleusercontent.com/-3...20-16_0025.JPG
https://lh3.googleusercontent.com/-x...0-16_0023_.JPG
Zoomin 07-10-2017 06:58 PM
Awesome build guys!
V8TV 09-26-2017 08:15 PM
The V8TV video highlighting this build...
gofastwclass 09-27-2017 06:38 PM
This car is probably one of my favourite builds because you spent so much time working around an already built car and making it look like you were never there. Excellent job.
I also like the videos. They give a bit of a different angle to the story.
waynieZ 09-27-2017 07:15 PM
I watched video this afternoon sweet looking car , nice job.
