Glad to see this back on track! The design work going into the front suspension is incredible!
Design and engineering in this build it top notch.:willy:
any updates on this?
Thanks for the bump. Unfortunately there has been no real progress. Other projects have taken up a lot of time. Both my brother and I have also been trying to focus on school, and being 3000 miles away from the car for most of the year doesn't help either. Alex has actually done quite a bit of cad work on the car, but we want to get in to manufacturing before posting any pics of that. I've picked up a lot more electronics stuff. A few months ago I developed an add-on board that will convert almost any Volvo from the 1980s to distributorless ignition. It also adds launch control and shift cut (for full throttle shifting). Here's a picture of it mounted and wired inside the ECU: https://lh3.googleusercontent.com/-Z...s640/photo.jpg The first production run: https://lh5.googleusercontent.com/-z...s640/photo.jpg Alex and I have also dumped quite a bit of time in to this project. It's a 73 VW beetle rallycross car. It was purchased as a rolling chassis (stripped, cage, 911 suspension and brakes, slicks, etc). https://lh6.googleusercontent.com/-G...0/IMG_7238.jpg We dropped in a 170hp 2.5l Volvo 20v 5 cylinder mated to a 4 speed vanagon transmission. Added a programmable EMS, coil on plug, individual throttle bodies, all new wiring, new fuel system, etc. https://lh5.googleusercontent.com/-z...s640/photo.jpg Here's a start-up video with the old intake manifold: https://www.youtube.com/watch?v=SjY_-ioMMsw So yeah, work on the 242 has been slow, but we've got tons of **** keeping us busy. Sorry for the lack of updates. Karl |
Awesome cant wait to see some stuff!
Gant,
Thanks for the pity bump. :( As usual, we haven't had any time for real progress. We've been doing a bunch of CAD work and the redesigned front uprights are coming along. We've also got a new powerplant with the "correct" number of cylinders for most guys around here. :P https://lh4.googleusercontent.com/-K...0/100_0595.jpg It's a 4.4 liter (268ci) DOHC V8 out of a Volvo XC90. It's stock rated at 315hp/315ftlbs. I talked to a good friend that works at the engine development lab at Volvo and said that if you remove the four cats from the stock exhaust it'll put out closer to 350hp. |
Awesome project (coming from a fellow ovlov nut!)! Also mixed emotions going from 5 to the 8 pot motor! but looks like you will pull this project off without no problems :)
Was that b8444s hard to find?
If you're in the market, a friend of mine has one that he's looking to move. |
any progress?? also, are there any aftermarket harnesses for that v8? or would it be easy to make it run with original harness? i would love this motor in a p1800!
| All times are GMT -7. The time now is 12:19 PM. |
