-   -   Sale on 1st. &2nd. Gen C-6 Camaro sub frames. (https://www.lateral-g.net/forums/showthread.php?t=30616)
coolwelder62 03-22-2011 03:35 PM
Originally Posted by drednot (Post 339528)
I suppose these subframes would fit a third gen Nova? On the C6 spindles, do you use the stock C6 or would the AFX work? Also what motor mount is on these again? Last question, is the trans mount adjustable? Sorry for all the questions, Thanks
They will work on novas from 68-74.They use stock c5/c6 splindles w steering arm cut off and mounting holes redrilled.the steering arms are supplied w/the subframe.Thanks Scott
jcal87 03-27-2011 09:03 PM
Ok so what can this Frame not do that AME or DSE can, aside from bent and hydroformed frame rails.
Track Junky 03-28-2011 07:20 AM
Cost you more money :unibrow:
Keep up the good work Scott :cheers:
coolwelder62 03-28-2011 03:34 PM
My sub frame is very close to the design Wayne Due used.I have been looking for some one to bend the 2x4 rec. tube for me but can't get them to call me back.So I may be looking to go another direction w/ my materials choice.And will start working on a new light wt.# design here in a few week's.It is very hard to find a company that can bend 2x4 each direction.And then getting them to give you a quote is even harder.So for now I will cut and weld the tubing the same way the Nascar team's build their Winston cup chassis.Thank's to all 25 customer's over the last 5 year's who have trusted me to build their componet's.:thumbsup: Scott M.
Track Junky 03-28-2011 08:14 PM
Any idea what a stock '69 subframe weight's in at?
jcal87 03-28-2011 09:03 PM
So tire size, suspension options,engine options its all the same?
coolwelder62 03-29-2011 08:42 AM
Using my fabricated sub frame on a 67-68 camaro you run a 18x10 frt wheel.The 67-68 camaro's are alittle narrower than the 69's .I have had an 18x11 on a 69 camaro w/no issues.And now my 72 camaro has 18x11's and they fit great.LS motors and T56's also work in them.I am working on finding a set of well built header's that will work w/the sub frame also.
coolwelder62 04-04-2011 06:29 PM
I guess I should have put the sub frame that I have left on this thread.
jamesg602 04-04-2011 10:29 PM
Coolwelder,
Would this subframe work with aftermarket a-arms say from DSE or speed tech etc? Do you know if I would be able to use my coilovers and a-arms from the DSE coilover kit (DSE speed package)?
coolwelder62 04-05-2011 05:29 AM
Originally Posted by jamesg602 (Post 341839)
Coolwelder,
My sub frame uses only C5/C6 componets.Sorry.
