Damn! Nice job on the dash. Great build you have going on.
9 Attachment(s)
Thanks for the compliments guys, heres some more updated pics. I got all the push buttons installed and the billet vent rings, the square box between the billet rings is the sensor for the Autometer GPS Speeedometer. Also finally got the intake so I don't have to use 4"x4" for mock up, I started working on my Custom Valve covers and made a 1:1 ratio linkage to connect the Dual Throttle bodies together. Also making a little more progress on the body(thats been at the shop for 1 year now). Enjoy
8 Attachment(s)
Heres a few more progress pics.
:wow: :y0!: More please.
:cheers: |
Looks great, the engine loks killer!
4 Attachment(s)
Well due to a Government shutdow I have plenty of free time as of today...So I stopped by the Powder coater and picked up my Ceramic coated headers, nothing like adding some more shiny stuff to the motor. I think I'll have them Ceramic coat my oil pan so everything sorta matches. I also worked on the 2" Valve Covers spacers so I can get them to eventually fit perfect to the valve cover, the Drivers side is almost done the passenger side isn't even started.
7 Attachment(s)
I finally had a chance to make the final version of the Radiator support cove this one is made out of .050" steel but I wont be able to test fit it untill next week then I'll weld the middle together and after some minor body work it will be ready for paint. Thanks for looking ...Enjoy
6 Attachment(s)
I also had a chance to make some more progress on the Valve Covers. I bonded the 2" spacer to the cover and sanded the two together to get a perfect fit, the thin line you see is the aluminum epoxy between the two pieces and you can't feel the line when you run your finger over it so when I paint them it will look like a 1 piece 5 1/4" Valve Cover. I also had a chance to make a set of Adjustable Aluminum front fender strut rods to replace the stamped steel factory ones (Last Pic).
Subscribed to watch this all come together, very nice.
I really like what you've done and the direction you're going with this car. Good job and good luck!
| All times are GMT -7. The time now is 01:45 PM. |
