You can T into the fuel line at the fuel rail And temp in a fuel pressure gauge. |
One day she will fire. :weld: |
2 Attachment(s)
Do you have 24 or 58 tooth reductor?
And is the ECU correct for the reductor you have? |
I'm thinking it's a fuel issue |
Is the fuel pump mounted above or below the tank?
How much gas did you put in the tank? I would recommend at least 5 gallons. If the pump is mounted high it may cause you problems. Most run in tank pumps....
Don |
| All times are GMT -7. The time now is 11:05 AM. |
