Sorry that was my brain trying to remember where that switch came from ....I was thinking 99- up gm trucks
Kevin, Thanks for the mirror pictures, what I'm trying to figure out is the best way to mount the mirror movement in the case. Are you fabricating something that ties into the mount for the stem? Also how are you interfacing the bullet mirror's plastic glass mount to the movement?
Since I'd already started wiring the car for c6 mirrors, I mounted a 4th gen Camaro switch in the stock chrome bezel in the door panel. It actually looks stockish if thats a look someone is after. |
After the sprayable polyester is block sanded using a guide coat, the body panels seam sealed to prevent moisture from getting between the overlapping panels.
http://www.v8tvshow.com/69_Camaro_ZR...5.28.14_01.JPG http://www.v8tvshow.com/69_Camaro_ZR...5.28.14_24.JPG http://www.v8tvshow.com/69_Camaro_ZR...6.02.14_06.JPG http://www.v8tvshow.com/69_Camaro_ZR...6.04.14_01.JPG http://www.v8tvshow.com/69_Camaro_ZR...6.04.14_04.JPG http://www.v8tvshow.com/69_Camaro_ZR...6.06.14_01.JPG The straightened panels were hung in the spray booth for a coat of high build primer. http://www.v8tvshow.com/69_Camaro_ZR...6.05.14_04.JPG http://www.v8tvshow.com/69_Camaro_ZR...6.05.14_10.JPG http://www.v8tvshow.com/69_Camaro_ZR...6.06.14_08.JPG |
The backside of the panels were then masked and sprayed with black Imron.
http://www.v8tvshow.com/69_Camaro_ZR...6.10.14_11.JPG http://www.v8tvshow.com/69_Camaro_ZR...6.10.14_12.JPG http://www.v8tvshow.com/69_Camaro_ZR...6.10.14_16.JPG The body shell was then moved into the paint booth, masked, and the exterior was primed. http://www.v8tvshow.com/69_Camaro_ZR...6.11.14_05.JPG http://www.v8tvshow.com/69_Camaro_ZR...6.17.14_01.JPG http://www.v8tvshow.com/69_Camaro_ZR...6.13.14_01.JPG |
The inside was sanded and prepped for black Imron. The interior, roll cage, dash, and firewall were all blacked out next.
http://www.v8tvshow.com/69_Camaro_ZR...6.17.14_05.JPG http://www.v8tvshow.com/69_Camaro_ZR...6.17.14_07.JPG http://www.v8tvshow.com/69_Camaro_ZR...6.18.14_06.JPG http://www.v8tvshow.com/69_Camaro_ZR...6.18.14_11.JPG Next the crew mixed up some of the jet stream blue to make a spray out card. The color looks outstanding in the sun! This is a color available on a late-model ZR1 Corvette, so it was a natural for the ZR9 Camaro. http://www.v8tvshow.com/69_Camaro_ZR...6.12.14_12.JPG http://www.v8tvshow.com/69_Camaro_ZR...6.12.14_25.JPG |
The body shell was then sprayed with guide coat, and all the parts were wet sanded smooth to 600 grit in preparation for color.
http://www.v8tvshow.com/69_Camaro_ZR...7.16.14_06.JPG http://www.v8tvshow.com/69_Camaro_ZR...7.16.14_08.JPG http://www.v8tvshow.com/69_Camaro_ZR...7.17.14_06.JPG http://www.v8tvshow.com/69_Camaro_ZR...7.17.14_07.JPG We sprayed Standox base coat and clear on the exterior panels. http://www.v8tvshow.com/69_Camaro_ZR...7.25.14_23.JPG http://www.v8tvshow.com/69_Camaro_ZR...7.25.14_37.JPG http://www.v8tvshow.com/69_Camaro_ZR...7.25.14_34.JPG http://www.v8tvshow.com/69_Camaro_ZR...7.25.14_42.JPG http://www.v8tvshow.com/69_Camaro_ZR...7.25.14_40.JPG |
Flush mount glass
We have Flush Glass in stock for this car just so you know. Looks awesome by the way. We also have tons of billet parts for this car along with interior parts if you are looking for some stuff.
Lots of awesomeness accumulating here. :thumbsup:
| All times are GMT -7. The time now is 10:58 AM. |
