-   -   Quintin Brothers- Fesler 1968 Camaro SEMA 2017 BUILD (https://www.lateral-g.net/forums/showthread.php?t=54769)
72Z/28 07-22-2017 02:16 PM
Great build, can't wait to see it whe it is done.
I noticed you guys will be using the tanks inc fuel tank. Are you going to upgrade the tank with dual fuel pumps to cater the power the engine is going to produce.
Another question regarding the A/C compressor, did you have to notch the frame to have a lower mount A/C compressor??
andrewb70 07-22-2017 03:01 PM
Nice to see the cleaner DBW TB. Looking good!
Andrew
Moabdude 07-23-2017 07:06 AM
Wheel and tires
Killer wheels. I love them!!
19/18 inch combo?
What size tires are you running?
QuintinBrothers 07-25-2017 04:59 AM
Hi, Thanks!
We were originally going to be using the Tanks Inc. Fuel tank with the upgraded fuel pump, but it turns out, that it did not fit with our Detroit Speed Tubs.. We are now using a fabricated Ricks Tanks setup.
Also, We did not need to notch the frame, but then again.. We did fabricate our own A/C compressor bracket.
Hope this helps!
QuintinBrothers 07-25-2017 05:00 AM
Andrew
Yea, Would of never went with the mechanical, This is a much cleaner look.
QuintinBrothers 07-25-2017 05:03 AM
19/18 inch combo?
Hi, Thanks! The wheels are 20x12 in the rear and 19x8.5 in the front.. We are working on tires as we speak!
rick7979 07-25-2017 08:57 AM
Who's console and steering wheel are you using? Thanks
simon455 07-25-2017 10:17 AM
Originally Posted by QuintinBrothers (Post 662871)
Hi, Thanks!
Hope this helps!
Hey, did the fuel tank from tank inc. fit between the spec chassis rear frame rails? wondering if ricks restomod tank would work with that frame set up...
QuintinBrothers 07-25-2017 10:54 AM
We are using a Billet Specialties steering wheel with a 2017 Camaro center console. Thanks
QuintinBrothers 07-25-2017 10:55 AM
Hi, The Tanks Inc tank was just about a inch to wide to fit.. The new RICKS Tanks does indeed fit great!
