Matt |
Thank you, G. :rofl: |
So Matt, tell me/us about the mod to the oil pan---looks like a windage tray--but it's for oil control I believe you said----would be curious as to its exact function and how you guys arrived at this paticular mod---looks like a stock LS pan.
Whatever you do, make sure it's ready to go by Friday morning-- D |
Let me retry this whole thing with some explanations/captions. I'm using the stock F-Body style windage tray (pictured below). I have been running this part since I got my car on the road. http://i366.photobucket.com/albums/o...A/IMAG0443.jpg This little bugger in the oil pan is what is new though. From what I've heard, it is a vast improvement over the stock baffled insert, which barely qualifies as a baffle when you hold the two side by side. I chose this for two reasons. First and foremost, my car has just been sucking up oil when going to the track. At Adam's Motorsports Park out in Riverside, roughly 20 laps around the little track completely filled up my catch can, to the point that it was no longer functioning, and was sucking oil through the PCV line from the valley to the intake manifold. Under normal driving conditions the catch can collects a little bit of oil, but nothing out of the ordinary. I think I've just been experiencing one of the known shortcomings of LS engines with stock oiling systems, and that is that these engines are prone to lots of oil aeration at high RPMs, as well as oil starvation. The other reason I decided to use the Improved Racing trap door baffle was because I wanted to keep my F-Body pan for two reasons. First, it is supposed to provide some structural support to the engine, and second, I'm not running a remote oil filter, which I believe is required with a Canton pan. http://i366.photobucket.com/albums/o...A/IMAG0444.jpg Here is a video someone posted on youtube showing how effective the little trap door baffles supposedly are: Is that a good explanation Doug? Matt |
Not bad sir. :D To think LS engines aren't perfect and Jason Pettis was right, stock LS oiling ain't that great.
We're also a day behind schedule. I was hoping to get the car dyno tuned today, but putting everything back together and getting fluids back in it took longer than expected. We had to jack the front of the car up to fill the radiator and get the thermostat working again. Tomorrow I'm hoping that TurnKey can get rid of a few pesky issues. The car almost refuses to drive at altitude, which isn't a huge deal because I'm not in the mountains often, however, I've always had to slip the clutch more than I'm comfortable with to get the car to go, and I really want to see if we can tune that out. As you guys can see though, she's back together now! http://i366.photobucket.com/albums/o...A/IMAG0448.jpg Matt |
Car is looking great and ready to roll
I put that same baffel in my F-Body pan. It works great.
Okay so where can I buy this baffled Windage Tray
| All times are GMT -7. The time now is 09:21 AM. |
