Amps make the starter turn over not volts. Volts can be a good indication but not a certainty. So if everything checks out, take the battery into a parts store. I believe most have a tester that can put a load on the battery. If not, grab the battery out of the wife's minivan and use it. If the car stops having problems, you found the culprit most likely.
With that said, use the multimeter at the alternator and the battery itself. No sense in trusting a gauge when you can measure with amultimeter right at the source. Don't measure at cable ground points. Instead, measure at bare metal spots that should also be grounded. That way you check the ground circuit as well as the output of the alternator. Check your battery cables. Ohm your power cables and the ground cables. Also ohm the connection points. By that I mean measure the at the cable clamp and the post or measure the cable and the frame on the ground side. You want it to be less than 1 ohm. Otherwise, the connection isn't as good at it could be. |
Before you spend hours and hours --- swap in a different battery and see if there's any improvement. If it improves you've found your problem - if not - now you can spend hours and hours... My guess is a bad battery ---- and or a starter that is getting heat soaked -- but it wouldn't be heat soak if you can't start it 3 or 4 times COLD... right in a row. ANY good battery should be able to start a car several times without fail. |
Made a little progress today.
http://photos.smugmug.com/photos/i-M...-M9W4sTC-M.jpg http://photos.smugmug.com/photos/i-X...-XKDSfnb-M.jpg http://photos.smugmug.com/photos/i-T...-TjH6nKm-M.jpg Driver quality at best but an improvement. ;) |
..... and surely you used self etching primer for that bare metal....
:cheers: :thumbsup: Next stop -- SEMA! |
SEMA :rofl: |
| All times are GMT -7. The time now is 07:55 AM. |
