Several flash lights and spare batteries. Cell phone car charger!
http://www.onelapcamaro.com/2010/hitch%20dev.jpg Another Pozzi original based on the factory design. |
How heavy is your trailer going to be?
just wondering if you are pulling strictly from the bumper? |
Never thought I'd say it but that's not bad. :unibrow:
it's just the start - it will be triangulated at the bottom as well and will be welded.
All told the trailer - loaded - will probably wind up being around 500 pounds - should be about 25 pounds on the tongue. |
How about a tap and die set and spray can of cutting oil.
Spare fuses, wire and splices for electrical issues |
Cool.. you know how some of our readers LOVE Camaros with trailer hitches.. lol
The good news is, I only had to drill two holes in the lower pan to get it on. With some black paint on it I hope it will not be so visible. This was fairly quick and easy and should be plenty strong enough for the weight we will tow. If I had more time, I'd make a square tube plug in version that could be left on the car, but this only requires 4 bolts and comes off easy. I need to start on the front hubs soon.
David |
ZR1 Hubs
David
What is involved in switching to the ZR1 hubs? How are they different than standard C6 hubs, and what do you gain -- stronger I assume. Will they alter any of the front geometry (scrub radius, etc)? Thanks. Pappy |
| All times are GMT -7. The time now is 05:59 PM. |
