As for the Woodward rack installation...its not for the meek. Woodward make the best racks in the business, bar none, BUT it is a racecar part and needs above average talent and resources to install correctly. You cannot order a rack for a 69 Camaro [or any other specific application]...their components are manufactured and sold by dimensional data.
On the 33 Ford we made the decision early on [after we discovered the inadequecies of the oem rack system] to do whatever it took to do this steering system right. This meant basically sawing off the front of the car and starting over. After the radiator and grille shell were out of the way, things cleared up nicely. Removal of a few more brackets and tubing cleared a path for proper placement. To determine proper placement we modeled the frontend digitally and ran the data through our suspension analyzer program. This told us exactly where the rack needed to be in every axis. We fabricated the neccessary mounts to put it there, ran the suspension through it's travel, and determined that there was less than .015" of bumpsteer through 6" of suspension travel. Winner! This also meant fabricating a set of custom steering arms to get the ackerman and bumpsteer optimized. Not a huge deal if you have a CAD guy 25 ft away and a CNC mill in between the two of you. Is it worth it? Obviously, because the alternative is that I have an expensive paperweight. [That would be a car that you can't steer] I point all this out not to explain how smart we are [we're not...if we were, we would have identified and fixed this problem months ago] but to demonstrate that sometimes hotrodding takes a little perserverence, a little money, a little talent, a lot of help from your knowledgable friends. Something to consider when you have to round the corner on a bracket or enlarge a bolt hole to get some aftermarket part bolted on your Camaro. Will we make it to Nashville Goodguys this weekend? I think so. |
Tuesday night...stuff left to do:
make steering arms [they're already designed and drawn up] build tie rod adjusters finish steering shafts design and build a power steering pump mount build another crank hub to accept an additional pulley for power steering design and build a power steering reservoir design routing and build 6 power steering lines design and build a new lower radiator hose figure out if radiator and grille shell will fit or if it needs to be moved forward That should keep us busy on Wednesday. |
Bret,The 33 is turning out great.:thumbsup: :thumbsup: :thumbsup:
Bret, these are the reasones that I like to let you guys design it and build it first then I can just buy it from you :thumbsup: Thanks for all the you and your guys do for our hobby. Ride Tech = class act :cheers: :cheers:
P.S. can't wait to get to the point to where I'm ready to do my front sub frame all RideTech going in there! :thumbsup: |
Well summarized update Bret, always look forward to reading them. :thumbsup:
The steering rack and radiator are back on and it looks like its going to be at Nashville this weekend! And if not we've always got a backup (1969 Silver Mustang)
http://www.ridetech.com/images/forum/33-ford/14/6.JPG http://www.ridetech.com/images/forum/33-ford/14/8.JPG http://www.ridetech.com/images/forum/33-ford/14/10.JPG http://www.ridetech.com/images/forum/33-ford/14/11.JPG http://www.ridetech.com/images/forum/33-ford/14/12.JPG http://www.ridetech.com/images/forum/33-ford/14/13.JPG |
Killer.:thumbsup: :thumbsup: :thumbsup: Is this car going to get a set of Ride Tech Shock's.:thumbsup:
Doesn't it already have a new set of adjustable Ride Tech shocks :rolleyes: http://www.ridetech.com/images/forum/33-ford/12/15.JPG |
Looking forward to seeing this car next week!
That '33 is sweet! I got a chance to see you out there running it today at Goodguys autocross. :thumbsup:
| All times are GMT -7. The time now is 08:29 PM. |
