-   -   IRONWORKS - 1967 Camaro with LT4, Forgeline's, Wilwood, Lots of new custom parts (https://www.lateral-g.net/forums/showthread.php?t=52107)
ironworks 02-20-2016 05:26 PM
Originally Posted by speedboats (Post 630525)
And created an account back in December two years ago just to post now?
Sorry, not really a mystery. I build jet boats for a living, even put an LS, LQ, LM in a few. I use the fab skills I see here to inspire some of my builds.
Big fan of Camaro's, ever since my Uncle rolled up in a 1978 Gen II when I was a kid. Of course I thought it was a Trans Am (Knight Rider and Smokey and the Bandit were on TV in that era), which my uncle quickly corrected.
Enough hi-jacking, I read the post and couldn't resist the reply.
Post some pictures of your work on here some where. I gave been thinking about building a crazy jet boat myself
ironworks 03-22-2016 03:43 PM
The progress has continued on the 67 Camaro at a pretty fast pace.
We have everything mounted under the dash. The Large Lt4 ECU, the EPS controller, the Raingear wiper system, the Vintage Air Gen4 unit, the Tilton pedal assembly with Throttle pedal and the EPS equipped steering Column. We had to recess the firewall in the middle to allow access to some connection on the back side of the engine and not have to move the engine forward. Things are very tight under the hood and under the dash.
http://i616.photobucket.com/albums/t...2016%20014.jpg
http://i616.photobucket.com/albums/t...2016%20021.jpg
http://i616.photobucket.com/albums/t...2016%20019.jpg
http://i616.photobucket.com/albums/t...column-01l.jpg
ironworks 03-22-2016 03:49 PM
The engine compartment is also pretty tight. The large wheel tubs pretty much kill any room around the wheels with the 19x11 Forgeline wheels. We also made an intercooler tank shaped to the curve of the inner fender to increase capacity as much as possible. The shocks on the Ring brother hood hinges needed to be relocated to the firewall down bars as they no longer cleared the wheel tubs.
http://i616.photobucket.com/albums/t...2016%20035.jpg
http://i616.photobucket.com/albums/t...2016%20011.jpg
http://i616.photobucket.com/albums/t...airway-01l.jpg
http://i616.photobucket.com/albums/t...2016%20025.jpg
http://i616.photobucket.com/albums/t...2016%20009.jpg
We modified the under structure of the hood for the vents and the aero latches.
http://i616.photobucket.com/albums/t...2016%20005.jpg
ironworks 03-22-2016 03:58 PM
We also installed the Speedtech torque arm mount into the unibody of the car. We had to remove the seat spot welds and set the outside of the top of the floor to attach to the subframe connectors under the floor. Works out pretty slick.
http://i616.photobucket.com/albums/t...2016%20016.jpg
http://i616.photobucket.com/albums/t...2016%20022.jpg
http://i616.photobucket.com/albums/t...2016%20001.jpg
We are just about ready to start body work on the car and get ready put this monster together for some summer time cruising.
LXSS350 03-22-2016 08:21 PM
That is taking shape really well, excellent workmanship and your planning is obvious. Well done. What EPS unit are you using?
ironworks 03-22-2016 10:16 PM
It's a unisteer set up from Speedtech
DOOM 03-23-2016 06:26 AM
Rodger its looking awesome!
ironworks 03-23-2016 08:44 AM
Hopefully we can complete the car before you or Bob.
King Nothing 03-23-2016 10:19 AM
Badass!!!
And I'll say this . . . man I hate being middle class lol
Ns RS 03-23-2016 11:00 AM
Exceptional work all around however is the owner short, loud and talks alot and will this be done by the hall of fame tour in sept? and how much of the billable hours has been spent listening to him talk alot loudly?? :burnout::burnout::burnout::burnout::burnout:
