-   Shop & Equipment (https://www.lateral-g.net/forums/forumdisplay.php?f=56)
-   -   New Shop Design help needed (https://www.lateral-g.net/forums/showthread.php?t=55157)
waynieZ 12-16-2017 09:16 PM
It's looking good, now you can see spaces coming together.
jarhead 12-17-2017 09:33 AM
WOW that really shows how big that shop is Lance :confused59:
Nice house too :-)
Joe
JKnight 12-17-2017 07:08 PM
Originally Posted by SSLance (Post 670412)
Thanks Jeff!! Say, I'm racing at AMP tomorrow if you aren't doing anything. Should be on track 10-11ish and then again 12-2ish for fun runs.
Dang it! I just saw this. We spent all day moving my bro-in-law. Otherwise I would have been there.
How’d ol’ Barney get along out there?
SSLance 12-18-2017 05:06 AM
Had a blast... Here was my last timed run, a 48.652... https://youtu.be/bMMQfXpoxsE
SSLance 12-18-2017 05:14 AM
Barney got to meet his new home yesterday.
https://photos.smugmug.com/Vista-Mon...ZRZVv56-XL.jpg
SSLance 01-02-2018 01:30 PM
So I got to spend some time with a tape measure inside the shop yesterday.
What should I consider a minimum distance away from a side wall for my drive on lift placement?
I have plenty of room toward the inside of the shop but my issue is lining up to the door. My 9' wide door is only 2 foot and change away from the outside wall and I need to get the drive on end of the lift as close to the door as I can to make sure there is enough room at the other end of the lift.
I can make it work with the drive on end of the lift being 3 feet away from the outside wall and the other end of the lift 4 feet away from the outside wall. Nothing has to be along that wall so there would be plenty of room to walk outside the ramp and also plenty of room to say pull an axle out of a housing or something like that.
Hopefully that won't be too cumbersome. I know it is not ideal, but for most jobs it should be okay, no?
The lift will have wheels so I guess if I really needed room around the outside of it I could load the car on the lift and then move it toward the center...but that would be an extreme case and not something I'd want to do on a regular basis.
Ketzer 01-02-2018 02:21 PM
I think that's one of the biggest pluses over two-post...
waynieZ 01-02-2018 09:08 PM
And I bet it was LOVE at first sight!
SSLance 01-03-2018 07:59 AM
I know... Trust me, I know...
But, with a two post I wouldn't have to move it in this situation...
dhutton 01-03-2018 10:03 AM
I would want a minimum of three feet of clearance to the wall with the car door open....
