First engine start 4-Mar-2023
Today was a beautiful Spring Day in the Phoenix area. Last time a fuel leak postponed starting the engine. I had some issues getting oil pressure to read out on the VCM dashboard even though it was working fine when I pre-lubed the engine. Not sure if I killed the sensor, have a wire issue, or just made a mistake in VCM. The plan was to run a few seconds and shut off early if no pressure reading which is what happened.
I bought a ratty mechanical gauge, pulled the sensor and we had a nice restart with plenty of oil pressure (about 100 psig over 3000 RPM). We had to do a quick throttle snap and my son shot a short video of the screen. We didn’t do any tuning. I noticed the idle is rough after throttle snap. Plenty of work to do to get it dialed in although surprisingly ok as-is. Impressions: • The install is a compete mess. All the wiring needs to be cleaned up, gauges installed, A/C wiper motor, lights wired, etc. • The VCM suite is surprisingly user friendly for an old guy • The engine sounded good to all of us, not too loud, good deep rumble but spicy with throttle • The exhaust note is more like the big block I previously had in the car which was a little unexpected (both 427 CID) • Not a drop of fluid leaked out of anything (newer engines are like that) • No black smoke out the exhaust just clean and lean • It was motivating to hear it run after all this time stuck building things and I do feel energized • Thanks a bunch to my friends Joel and John and my son Tristan for helping out |
:thumbsup:
| All times are GMT -7. The time now is 08:21 PM. |
