-   -   1970 402 BBC + tons of extras (https://www.lateral-g.net/forums/showthread.php?t=10633)
patgizz 08-08-2007 06:49 PM
i'm going another direction with my project. please bring me cash and make this disappear.
1970 SS396/350hp block CTW, D13 70. has been tanked, fluxed, honed, new cam bearings, new plugs, painted, and greased up to prevent rust. caps incl.
71 3993820 heads off an LS5. oval/open. pulled from a non smoking runner a few years ago.
3/8" rods with new bolts
6223 forged crank - needs turned.
new gm billet hydraulic roller cam, .483 lift (must use gen6 timing set)
melling timing set for standard flat tappet cam
oil pan from a crate motor
moroso stamped aluminum tall valve covers
timing cover blasted/painted
SFI flexplate(out of date)
new head bolt set
new comp cams pushrod set for flat tappet cam
edelbrock torker II 2-0 intake
new q-jet from big caddy application w/ adapter for squarebore intake
HEI distributor
used crane/cam dynamics roller rockers that i just bought for it
used speed pro forged pistons that i bought from a member here. supposedly good, all but 2 seem fine, those 2 have the wrist pins stuck in them.
moroso alternator bracketry
$800 - pickup only in medina ohio 44256. i've been offered $800 for the block ALONE by a SS396 owner - but was too into it to sell at the time. my loss, come get it.
