Flywheel Part #
I know this question has been answered before but can someone tell me the part # for Mcleod flywheel for two piece rear, pull style T/O bearing for an
LT1 T56 to gen 1 swap |
Looking through my notes, I have No. 460370 wrote down. Hope that helps.
thanks!
Conversion p/n's.
460370 shows for a one piece rear main engine. 25lb. 460300 is for a two piece rear main, internally balanced engine. 30lb. 460300-2C , ditto, externally balanced. 30lb. 700107 is the Centerforce flywheel, 2 piece, internal. 29.3 lb. 2555 Ram, ditto, ditto. But aluminum. 18lb. Double check with manufacturer before ordering. :thumbsup: |
Btw.. are those Gm performace crate small blocks( like ZZ4? ) externally or internally balanced ??
| All times are GMT -7. The time now is 01:24 AM. |
